Air Down/Up Tools
Discussion in 'Wheels & Tires' started by K-Paul, Sep 17, 2021.
  1. Sep 17, 2021 at 10:03 AM
    K-Paul
    K-Paul [OP] Looking for a water crossing
    Corbin Dallas
    SR5 4WD
    Just curious how many of you have had a chance to use a speedflate? If so, what air compressor are you using?
    For those not in the know: https://www.speedflate.com
  2. Jan 9, 2022 at 6:58 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Since I shared the thread I have made some purchases. I changed the title to the thread, maybe just hearing everyone's setup might be more helpful to some. Eventually I saw a Youtube vid where this $114 air compressor took on the ARB and put it in an MMA sleeper hold.
    Maxi Trac Air Compressor:
    https://www.napaonline.com/en/p/BK_MTWM10215C?impressionRank=1
    Youtube vid:
    https://youtu.be/2EVtW34U8Fw
    Here are my personal statistics using Falken Wildpeaks 265/70/R17 (TRD Wheels) Starting @ 36 Psi (Speedflate inflating or deflating all four tires at the same time)
    Air down W/Speedflate to 17PSI - 2 min 25 seconds.
    Air Up with Maxi Trac 17Psi to 36PSI - 2 min 16 seconds.
    When I used the Smittybilt 2781 ($169) on my last trip with the Speedflate pump time was 7 min 42 seconds from 20 Psi to 36 Psi. The Maxi is a two piston system like the ARB. obviously with a 470+ dollar gap, the assumption is the ARB will last longer. Im curious if anyone else is using the Maxi for applications other than tires?
    9BD184AC-FDAF-4501-9465-57FD42B96C78.jpg 39FEF9D9-A4A3-40F2-A6D1-E1AD45B18BD3.jpg 4EC2A2F0-4A48-486D-BE50-18F99467F4D0.jpg
  3. Jan 9, 2022 at 7:04 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I’ve never seen that, but it’s pretty damn cool. Napa even put out their $100 awning that sold like hot cakes.
    I like my ARB twin, but definitely pricey.
  4. Jan 9, 2022 at 7:08 PM
    Hopefully the maxi Trac lasts for you.
    K-Paul[OP] likes this.
  5. Jan 9, 2022 at 7:29 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    For sure I agree. If I had to use the compressor for anytbing other than tires im 97% for the Arb. The reliability of this Maxi is what will make or break it.
    And that NAPA awning? its been sold out for like 5 months
    The Knitted Brow and Thatbassguy like this.
  6. Jan 9, 2022 at 7:31 PM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    I honestly like Morrflate better, and I just hard mounted a 400ah in engine bay.
  7. Jan 9, 2022 at 7:47 PM
    I'm surprised how expensive some hoses and fittings are! I just do one tire at a time. :D
    Jynarik likes this.
  8. Jan 9, 2022 at 8:07 PM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    same. That thing is a $175 convenience fee
  9. Jan 9, 2022 at 8:21 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Well, yeah, it is convenience. I wouldn't buy it if it were anything less :bananadead:
  10. Jan 9, 2022 at 8:23 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Yes, I do find it to be the more superior hoses. I dont like that the hoses coil up. I find it takes more space than just having a few straight hoses. Speedflate used to make them that way. Not sure why they went with this design.
  11. Jan 9, 2022 at 8:35 PM
    My inflator came with a coiled hose, and I didn't care for it, either. I replaced it with a straight hose. It packs away nicer.
    K-Paul[QUOTED][OP] likes this.
