Air Compressor/Inflator for the 4Runner
Discussion in '5th Gen 4Runners (2010-2024)' started by BeavertonCommuter, Oct 15, 2021.
  1. Oct 15, 2021 at 1:42 PM
    BeavertonCommuter
    BeavertonCommuter [OP] New Member
    Im looking at the four compressors below and would appreciate any user feedback. I've got stock sized Falken Wildpeaks and will be doing plenty of airing down through the fall and into the winter.
    VIAIR 300P Portable Compressor - $186
    VIAIR 400P Portable Compressor - $230
    Ironman 4x4 AIR CHAMP PRO 5.65CFM - $199
    Smittybilt 2781 5.65 CFM - $212
    The VIAIR's, of course, have great reviews here and Ive seen a few for the Smitty as well, though not much on the Ironman. Ive included Ironman because their ship is 15 minutes from home and their price competitive with coupons available to bring the price down further.
    Appreciate any feedback.
  2. Oct 15, 2021 at 1:48 PM
    I believe the Ironman is a rebranded Smitty.
  3. Oct 15, 2021 at 1:56 PM
    Not on your list but I have a Viair88P, used it once, it seems like a good quality portable compressor.
    Your right, the Viair get pretty good reviews online.
  4. Oct 15, 2021 at 2:01 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I’d just pick the one with the best warranty. I have ARB on board so can’t comment on those. But I will say if you plan on getting bigger tires and wheeling, spring for ARB twin compressor
  5. Oct 15, 2021 at 2:05 PM
    I have the Viair 300P. It gets my 295/70/17's from 20 PSI up to 35 PSI in about 2 minutes apiece. I'm totally satisfied with it. For stock size tires, it should be more than sufficient. I would absolutely buy it again. :)
    icyhotahs, DRobs, Roland and 2 others like this.
  6. Oct 15, 2021 at 2:22 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Roland likes this.
  7. Oct 15, 2021 at 3:06 PM
    studiousjr
    studiousjr New Member
  8. Oct 15, 2021 at 3:07 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    No experience but own one o_O
    Edit: It's the 400P, 300 CFM Model #44034
  9. Oct 16, 2021 at 7:52 AM
    2000Sport
    2000Sport New Member
    HUDSON VALLEY NY
    OG Gen 5 2013 Trail ~Classic Silver ~ KDSS
    Very pleased at the performance of the Smitty 2781. Many air up cycles on 275/70/17 this summer, worked flawlessly. 188.00 on Amazon.
  10. Oct 16, 2021 at 9:00 AM
    Definitely Viair out of those. I have a 450P.
    DRobs, Roland and Thatbassguy like this.
  11. Oct 16, 2021 at 10:13 AM
    MAXIM
    MAXIM New Member
    You have to buy it only once, get best of the best out there. Here is my with 1 gallon air tank under mounting plate:
    -and-lt;-and-lt;-and-lt;-and-lt;-albums-_c88d20716ca3470eae5f6d9b52f7c2795d46deb5.jpg
    GPFREE likes this.
  12. Oct 16, 2021 at 11:15 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I also have the Viair88P. Works for me. It’s light and small enough to easily stash in the back where it stays clean.
    7385 likes this.
  13. Oct 16, 2021 at 12:49 PM
    jetmechG550
    jetmechG550 New Member
    Frank
    2021 Off Road Premium
    Best flow rate and duty cycle should be the determining factor
  14. Oct 16, 2021 at 9:21 PM
    It looks like it has roughly 1/3 more output than the 300p. I'm using a 300p on 295's and it's been great so far. If you're going bigger with tires, or just want it to work faster, it seems like the 440 will be fantastic.
    The ARB twin looks great if money is no object, and if you want to mount your compressor. But, the OP seems to be looking for a portable compressor.
    BeavertonCommuter[OP] likes this.
  15. Oct 17, 2021 at 12:53 AM
    I looked at the specs of the 300 and 400 Viairs and am a little confused at what differs between the models. They seem to have the same duty cycle and airflow cfm. What differentiates the models then?
  16. Oct 17, 2021 at 5:11 AM
    I noticed that when I was looking to buy mine. I can't recall if I found any difference between the 2 other than price. :notsure:
    Edit: I was curious... The 400p can achieve higher output at 24 volts. So, nothing useful unless you plan on running dual batteries.
  17. Oct 17, 2021 at 5:32 AM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I have this exact same setup. Really enjoy my ARB. I also have the single as well that I have in my wife’s van. It is cool that you can run pneumatic tools with the dual ARB compressor and the one gallon tank.
    single:
    dual:
    Yes both of these are higher priced than vivair but honestly buy once cry once (in my case I bought twice and cried twice). But in all seriousness the single sold me on the double. I filled up 4 of my tires and put everything away and my neighbor was only on his second tire (I went all the way up to 55-60 psi and he was going to 45). I pulled everything back out and had filled up his 4th tire and he just was getting to his 3rd tire. Offered to do his 3rd tire as well to get done faster. We both are running 34” tires (285/75/17).
    4R21 likes this.
  18. Oct 17, 2021 at 6:04 AM
    JaSC
    JaSC New Member
    Anderson, SC
    Black 2018 4Runner TRD Off Road Premium, crawl control and MTS
    ToyTec Lift, Dual Batt Redarc. Rear safe drawer, console safe, Aux 2004 JGC fuse box, Warn bumper, 12,000lb winch
    The ability to run air tools is a incentive for sure. I wonder if I could adapt a 'bail-out' bottle as a mounted tank since I don't dive anymore.. It's a Al30 (30cf), out of vis and hydro inspection. I hate to see it unused.
    Anybody got thoughts on feasibility?
  19. Oct 17, 2021 at 8:09 AM
    55-60 PSI???
    285/70/17's (assuming LT) should be run at 35 on our 4Runners.
    Also, which Viair was your neighbor using? The ARB has great output, but I'm not having any issues with 295's and a Viair 300p.
  20. Oct 17, 2021 at 8:30 AM
    Portable compressors with automatic shutoff come into play when moving from tire to tire, and when checking tire pressure in the middle of a tire fill. A typical portable compressor must be turned off between tire fills, and anytime you want to check tire pressure. If you aren’t near the compressor, this can turn into running laps back and forth to the portable compressor to turn the unit on and off. Automatic portables do not work in this fashion and will save you time & effort to get tires inflated quickly
  21. Oct 17, 2021 at 9:59 AM
    GrantA
    North Carolina
    Sorry my post might have been misunderstood. Idk if he was running Viair pump or just a cheap autozone pump. I did ride with a guy that had a Viair pump and it seemed to run good but that is my only experience.
    Yep running 55-60 psi:
  22. Oct 17, 2021 at 10:16 AM
    The sidewall shows maximum inflation at maximum load. 55 is WAY too high for our trucks.
    Thay ARB twin seems like a great option for those looking to do an onboard mounted compressor. Looking at the specs, it has very good output.
    Roland likes this.
  23. Oct 17, 2021 at 11:21 AM
    GrantA
    North Carolina
    Oh I might go drop the tire pressure now to 40.
  24. Oct 17, 2021 at 11:52 AM
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
  25. Oct 17, 2021 at 12:09 PM
    This is a good tool to find the recommended tires pressure for oversized tires. I know some people prefer to run a little higher or a little lower than the recommended pressure but it is a good starting point
  26. Oct 17, 2021 at 3:21 PM
    SunnyTRD
    SunnyTRD New Member
    2020 TRD Pro
    TBD
    I have the 400P Auto and like it, although the gauge is slightly off. I may see if Viair will replace it. I replaced the battery connectors with a plugin connector. Overall I don't spend too much time bringing up to standard pressure from 15psi. I do not have anything to compare with however.
  27. Oct 18, 2021 at 11:22 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Something for the DIY GUYS. Turning a pump on and off without having to go to it is possible. Replace the on/off switch(low volt/amp) with one of these(two wires in & two wires out). Have been using them(where needed)for years.
    https://www.amazon.com/Fimco-777193...words=remote+switch+12v&qid=1634623624&sr=8-7
  28. Oct 20, 2021 at 3:54 PM
    My solution was to make my own hose, putting the gauge right at the compressor. I still have to flip it off to check the gauge, but it saved me a bunch of running around.
    https://www.4runners.com/threads/th...ll-of-my-money-went.12919/page-15#post-258802
    @Moon Landing that looks like a slick device! I'll be keeping that in mind for future projects.
    DRobs likes this.
  29. Oct 20, 2021 at 4:03 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
  30. Oct 20, 2021 at 4:18 PM
    ubertoyotax
    ubertoyotax New Member
    Buy once cry once, get an ARB twin. My buddy had a VIAIR and ended up selling it for an ARB.
