Aggressive or Over sensitive Abs When snowing - 5th gen 4runner
Discussion in '5th Gen 4Runners (2010-2024)' started by Kimo, Feb 18, 2022.
  1. Feb 18, 2022 at 7:25 AM
    Kimo
    Kimo [OP] New Member
    2021 4runner nightshade
    So basically I live in good old Quebec, I have 2021 4runner and the brakes suck when it snows. I have bridgstone blizzarks V2 on some replika wheels. The Abs just goes of when there is a an inch of snow. I always keep a safe distance from the car in-front of me and brake gently and decelerate slowly, but when it gets to the last few inches of stopping distance to get to a complete stop my ABS turns on for no reason the brake pedal shakes and I lose all braking power. I feel like I am always going to crash on 10 km/h. Today the same thing happened on a red traffic light.
    Any ideas what to do?
  2. Feb 18, 2022 at 2:37 PM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    I've had the same experience. I "think" that you can deactivate the ABS when pushing and holding the traction control button for at least 5 seconds while stopped. I deactivate mine all the time and pretty sure the ABS gets kicked off as well.
    PS: Dunno about "good" ole Quebec, but I'm from the South Shore of Mtl. *wink*
  3. Feb 18, 2022 at 2:40 PM
    Kimo
    Hahaha close enough. Thanks, i thought of doing that. Do you disable traction and stability control or just traction?
    Also, wont i lose traction if i turn off “traction control”. I thought I should only do that when I am stuck.
  4. Feb 18, 2022 at 2:47 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Yes, you do. I'm old-school and hate that stuff. I'll use it in dry conditions but when it snows, it all gets deactivated. The ABS alone has caused me a couple of close calls in snow when city driving
  5. Feb 18, 2022 at 2:50 PM
    Kimo
    Yeah me too! Well that sucks I think i will leave the stability control on and see what happens. I never found it lacking on high speeds its just in the city coming to a complete stop sometimes is scary.
  6. Feb 18, 2022 at 3:17 PM
    Taco4R
    Taco4R New Member
    2022 TRD ORP Classic Silver Metallic
    yeah the suddenly shifting and losing all power is a bit stupid, always assumed it was because I was just running the stock highway tires.
    I don't have the patience for two sets of tires and haven't got around to getting ATs yet so I lean on 4WD quite a bit right now.
  7. Feb 18, 2022 at 3:44 PM
    Kimo
    I basically drive a limited so its all time 4wheel drive. Does not really help and thats with winter tires.
  8. Feb 18, 2022 at 5:51 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    Interesting. I've experienced the ABS kicking in when slowing to a stop on snow, but attributed that to the crappy OEM tires on my Limited -- because, and here's the key, the truck would also slide even with the ABS activating. Clearly, the ABS is not overactive if the truck is sliding. It's exactly when sliding that you need the ABS. That's what it's for.
    Would like to hear what others are experiencing, but would be surprised if the main issue is the ABS system and not the tires.
    Also, the idea that one loses all control because the ABS kicked in doesn't make sense. ABS is there to restore some of the control you're losing because your tires lost grip. Sure, it would be annoying if ABS activates when not necessary to prevent sliding, but it's hard to see how that would be happening. The whole thing is designed to operate only when the vehicle is moving despite the tires not rotating -- aka you're sliding.
    jth likes this.
  9. Feb 18, 2022 at 6:40 PM
    Kimo
    Okkkk so ….. I do agree with you the abs is trying to help but fails, and funny thing the same issue just happened to me 5 mins ago. I think my solution is to press the brake firmly like to the maximum peak and it helps. The abs does not take over 100% but I lose most of my breaking power and I need to press the brakes extremely hard. Also, I disagree about the orm tires, because I am running winter tires.
  10. Feb 18, 2022 at 10:46 PM
    I don’t think the “Trac/Vsc”switch turns off the ABS but I could be wrong. I wasn’t crazy about the electronic systems either but I have experimented with them on and then off in slick winter conditions and I’m sold on them. IMHO they help a lot.
    5thToy and Singleminded like this.
  11. Feb 19, 2022 at 6:11 AM
    auspilot
    auspilot Old Member
    2020 TRD OR
    Dobs IMS, lots of small stuff
    I was under the impression that ABS does not engage at very slow speeds like under 5mph, at least on some cars. Is that not the case?
    peter2772000 likes this.
  12. Feb 19, 2022 at 6:30 AM
    Singleminded
    OEM LED foglights
    I’ll add that I drove my wife’s 2021 Passport in the snow recently and it’s ABS also kicked in when coming to a stop at slow speeds. The difference was that it worked — the truck didn’t slide anyway. In the same snowstorm my 4R on its OEM tires (which are known to suck in the snow) slid 5-10 feet at very slow speeds with the ABS activated the whole way. I was just pulling up to my driveway at a few miles per hour and it slid right past it. That’s nuts. And dangerous. That’s bad tires, not the fault of the ABS.
    jth likes this.
  13. Feb 19, 2022 at 7:28 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Time for an ABS refresher.
    From the owners manual:
    https://www.confused.com/car-insurance/guides/what-is-abs
    • ABS can stop your brakes from locking.
    • ABS isn't designed to shorten stopping distances.
    • Having ABS should reduce your chances of skidding.
    • The ABS system isn't as effective on surfaces like mud, snow or gravel.
    erfer1, 2Toys, 5thToy and 1 other person like this.
  14. Feb 19, 2022 at 1:59 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Delete
  15. Feb 19, 2022 at 2:02 PM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Well, I was wrong. It snowed quite a bit last night and I did the usual routine. ABS is still engaged. And still a royal pain in snow in town.
    Time for more research. On my FJ, I'd spliced a switch in one of the OE wires which killed all that shit at once.
  16. Feb 21, 2022 at 8:07 PM
    Singleminded
    OEM LED foglights
    I'll be interested to see what happens with my new tires. I had the sliding while stopping problem on the standard-load, touring type tire that my Limited came with. Now I have E Load tires that are Severe Snow (Three Peak) rated. I'll be shocked if they are as bad as the standard load touring tires. I expect they will be lightyears better. Again, both E Load and Three Peak snow rated.
  17. Feb 21, 2022 at 8:27 PM
    Kimo
    @hallcs i am not good with tires what type of tires are you tunning that are E rated. I am guessing my load range is SL for the blizzak dm v2 265 70 17
  18. Feb 21, 2022 at 8:37 PM
    Kimo
    Yeah but those wont work in Quebec. Ill try my luck with some michelin next time maybe going stubbed. I dont know.
  19. Feb 21, 2022 at 8:50 PM
    Kimo
    Yeah I wish I could ride on my 20s all year long I do a lot of highway driving and I just notice the difference.
  20. Apr 10, 2023 at 12:06 PM
    Leadnuts
    Leadnuts New Member
    Hi, I sorry it’s an older thread.. I haven’t seen an actual answer anywhere.
    I have a 2017 Off Road. I’ve had it maybe a couple years now. Since then I’ve had the same 5 or so panic attacks from lockups from what I think aren’t all necessarily that aggressive of stop attempts.
    but when I’m all packed with gear and I hit the brakes on a dry normal paved road and they lock up sending me into panic inducing fishtail swerves. When everyone else is coming to a. Stop like normal people. The guy behind me thought I had a wheel come off.
    I’d love an update. If someone had a moment.
  21. Apr 10, 2023 at 1:53 PM
    Sounds like you may be overweight. Manufacturers establish a max weight for a reason.
    4oreigner likes this.
  22. Apr 10, 2023 at 5:37 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Wheel speed sensors don't usually lie. If ABS is coming on its because a wheel is locking up. It's designed to allow steering control not stop faster. That said I have seen wheel speed sensors drop out at low speeds mimicking a locked wheel but only on wheel speed sensors with an adjustable airgap that was out of spec.
    jth likes this.
  23. Apr 10, 2023 at 6:07 PM
    Leadnuts
    Leadnuts New Member
    It has happened without any extra load as well.
  24. Apr 10, 2023 at 6:16 PM
    Leadnuts
    Leadnuts New Member
    I’m pretty sure abs isn’t coming on in those instances, or I think I’d have felt, heard, or seen the light. Also, like I touched on, I was not jamming the brake pedal down in an emergency (at least for a couple of them) , just more rapid than a typical braking.
    I would be getting some form of error for a sensor out I’d think.
  25. Apr 10, 2023 at 11:04 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Anecdotally: I’ve run 10’s of thousands of miles on Bridgestone Duelers and Michelin Defenders.
    City driving in snow/ice/slush my ABS and traction control kicked in constantly with the stock Bridgestones. When I installed Defenders, I noticed an immediate difference. The ABS and traction control systems rarely engage with the defenders.
    I’ll also add that traction control has without a doubt saved my ass on the highway on occasion. Those random times when the truck downshifts at the very moment you hit a scattered icy or wet patch.
  26. Apr 10, 2023 at 11:18 PM
    steelevo
    Utah
    I have never had this issue on snowy roads with Blizzak DMV2's. Only during hard braking and icy roads. All other times, I was able to stop and start as normal. This was both in a 2016 limited and 2020 Pro. Haven't had much of a chance to test anything in the 2023 Pro on snowy roads yet.
