Aftermarket e locker
Discussion in '5th Gen 4Runners (2010-2024)' started by deltabravo, Oct 5, 2024.
  1. Oct 5, 2024 at 8:20 AM
    deltabravo
    deltabravo [OP] Strongest steel is forged in fire of a dumpster
    East Coast USA
    Hey guys I have a 2023 SR5. Considering throwing on an Eaton Elocker on it.
    anyone have any experience doing this? What was your thoughts? Just as good or better as the locker on off road models?
    thanks
  2. Oct 5, 2024 at 9:18 AM
    OdyRunner
    OdyRunner New Member
    I have a friend who installed a front e-locket from Easton on his Tacoma and said it functions the same as the factory rear locker. If I install a front e-locker it will be an Easton.
    deltabravo[OP] likes this.
  3. Oct 5, 2024 at 10:56 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Check out ECGS for a 3rd member with the locker installed. That’s how I upgraded my LE.
  4. Oct 5, 2024 at 11:52 AM
    deltabravo
    East Coast USA
    call me dumb but what’s an LE?
  5. Oct 5, 2024 at 12:12 PM
    Limited.
  6. Oct 5, 2024 at 12:30 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Did you upgrade to 4.56 or 4.88 gear while doing this?
  7. Oct 5, 2024 at 4:37 PM
    nova
    nova New Member
    mike
    I went with ARB lockers and 4.88. I’m able to manage what amounts to almost 100lbs per corner and 35” Toyo MTs. My next tire might be MT Baja 37”. They weigh about the same.
  8. Oct 5, 2024 at 11:34 PM
    I would keep a notepad in your glovebox and record each time you get stuck because you didn’t have a locker. When the score gets to three, buy a locker.
    icebear and deltabravo[OP] like this.
  9. Oct 6, 2024 at 7:42 AM
    deltabravo
    East Coast USA
    bro this is brilliant
  10. Oct 6, 2024 at 9:58 AM
    nova
    nova New Member
    mike
    There’s more to it than forward traction. Down hill control is improved using the rear locker while engine braking. Especially if the hill is rutted. Here’s a good explanation
    https://m.youtube.com/watch?v=lFB7JhwSCdU
    J0hnny likes this.
  11. Oct 6, 2024 at 12:52 PM
    deltabravo
    East Coast USA
    So better than factory locker?
  12. Oct 6, 2024 at 3:25 PM
    nova
    nova New Member
    mike
    Do you mean is the ARB locker better than the factory E-locker? You could argue the carrier on the ARB is beefier but there’s notching wrong with the OE locker per se. Especially if your rig came with it!
  13. Oct 6, 2024 at 6:45 PM
    ADV4RNR
    ADV4RNR New Member
    Bob
    2019 Off-Road Premium
    typical lift, tires, skid plates and rock sliders
    After market lockers can be run in 2WD and 4 Hi..... while the factory locker only works in 4 Lo, and automatically disengages at a particular speed (I forget the exact speed....but remember it's relatively low).
  14. Oct 6, 2024 at 9:20 PM
    icebear Recovered Kia Owner
    That post is solely talking about the utility of a rear locker downhill, I don’t think there’s anything to lean towards OEM or aftermarket in that context.
