AFE throttle body
Discussion in '5th Gen 4Runners (2010-2024)' started by Gstick, Jul 21, 2023.
  1. Jul 21, 2023 at 9:35 PM
    Gstick
    Gstick [OP] New Member
    19' TRD OFF ROAD
    Just asking if there would be any noticeable gains whatsoever by putting on a 76mm AFE throttle body vs the OEM stock 70mm throttle body?
  2. Jul 21, 2023 at 9:40 PM
    If there was, wouldn’t the Toyota engineers have thought of it?
    djb1 likes this.
  3. Jul 21, 2023 at 9:51 PM
    Maybe if you had a supercharger.
  4. Jul 22, 2023 at 5:20 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Short answer is yes. The longer more accurate answer is there would likely be very small gains that probably would not be noticeable. AFE states some users will notice increased idle rpm for as much as 800 miles while the ECU learns to properly control the idle. Translation....this throttle body allows more air making the fuel/air mixture leaner until the ECU compensates. Additionally, AFE also states performance gains will be more noticeable as more upgrades are added. Translation.....you won't notice any gains by simply adding this throttle body.
    IMO, the simplest way to affordably increase noticeable performance is with a good tune like those offered by OTT.
  5. Jul 24, 2023 at 1:52 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I didn't realize they even sold a larger aftermarket throttle body. Now I'm curious.
  6. Jul 24, 2023 at 2:29 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    No. Wallet lightener.
    Ironguy, 2016Pro and 08TXRunner like this.
  7. Jul 24, 2023 at 9:15 PM
    I only see spacers available from AFE for Runners anyway. Those do absolutely nothing.
  8. Jul 25, 2023 at 8:09 AM
    2016Pro
  9. Jul 25, 2023 at 8:09 AM
    2016Pro
    A tune on a naturally aspirated motor won't do much.
  10. Jul 25, 2023 at 3:01 PM
    3JOH22A Toyota Gigolo
    How often do you do full-throttle launches with the pedal pinned to the floor? By definition that's when a larger throttle body will have an effect.
