Advice on Bilstein shocks
Discussion in 'Suspension' started by Toy4X4, Mar 13, 2025.
  1. Mar 13, 2025 at 3:32 AM
    Toy4X4 [OP] New Member
    Who has the 6112 front, 5100 rear setup? Also what rear springs did you install? Considering going with this setup but don't want to compromise on road manners too much. Going for a 3"/1.5" stance. Appreciate feedback on this, Thanx.
  2. Mar 13, 2025 at 3:46 AM
    I had this setup from April 2020 until this February. I had the medium load 6112's set to ~2.4" lift.
    I put around 100K miles on them. I was seriously considering going with them again, but wanted to try OME MT64's and got a deal on the rears.
    In some ways, I thought the Bilsteins had better road manners than the OEM shocks. A firmer ride, which has pros and cons.
    The only complaint I had was that the rear felt bouncy at times. But, I thought that might have been due to using heavy springs (Bilstein B12 heavy load). It felt like the 5100's didn't have enough damping for the extra weight and stiff springs.
    If you're not carrying a lot of constant weight, you could go with the standard load B12 coils, and the ride would probably be fine.
  3. Mar 13, 2025 at 4:25 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    6112/5100 here. Running a T13 rear spring. I had my clips set at 6 and 4 for the front. That got me about 2". Absolutely happy with the ride. I have a deck box with drawers. It puts about 1/4" drop in the rear.
    TrailSpecial22 and Toy4X4[OP] like this.
  4. Mar 13, 2025 at 4:35 AM
    Knarf
    Knarf New Member
    DFW
    2024 White SR5
    I'm running them with standard load springs, 6/4 fronts and B12 rear 1" standard load. I had 5100 all around w/ stock rear spring and felt it was a bit rough, the 6112 provides that bit more softness on road that was perfect for me. Also moved to 285/70s with perry bump stops at the same time so not sure if that played a role as well.
    You can pickup this setup from RockAuto for way cheaper than anywhere else too + add discount code.
    Toy4X4[OP] likes this.
  5. Mar 13, 2025 at 7:20 AM
    TxTRD
    TxTRD New Member
    Tx
    22 TRD ORP
    @Knarf where in DFW are you located? Thinking of going the 6112/5160 route.
  6. Mar 13, 2025 at 7:26 AM
    Knarf
    Knarf New Member
    DFW
    2024 White SR5
    Hey man, I'm in the Carrollton area. Thought about 5160s also, but don't need the extra oil capacity and you only gain like 1/4" more of down travel if I remember that correctly.
  7. Mar 13, 2025 at 9:24 AM
    HuskyMike
    HuskyMike New Member
    I have the 6112/ 5160 combo. I have the B12 "special" rear spring. From reviews I've seen, people don't think there is much difference between the 5100 and 5160.
    I'm happy with the ride over stock. On slower speed bumps, I wish it was a bit more soft, but otherwise, no complaints. I have about 20,000 miles or so on them.
  8. Mar 13, 2025 at 9:50 AM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    Are you planning to get the lift from springs or from the circlip adjustment?
    Toy4X4[QUOTED][OP] likes this.
  9. Mar 13, 2025 at 12:29 PM
    This would be experimental, but something you could try instead of doing the B12 coils combined with either the 5100 or 5160's in back, is combine the B12's with Eibach rear shocks. I think the valving is a little softer on the Eibach's and they might be a good match with 6112's up front.
  10. Mar 13, 2025 at 12:39 PM
    BLKNBLU
    BLKNBLU New Member
    I'm not following what is experimental?
  11. Mar 13, 2025 at 1:19 PM
    Combining 6112's with Eibach rear shocks.
  12. Mar 13, 2025 at 2:11 PM
    BLKNBLU
    BLKNBLU New Member
    Gotcha. I was considering that as well. I just mis-read it.
    nimby[QUOTED] likes this.
  13. Mar 13, 2025 at 2:20 PM
    Wren
    Wren New Member
    I tried both 5100 and 5160 back to back matched with 6112 front. I thought the 5160 was a much better match and would highly recommend going that route. It’s not a huge price difference and it was a noticeable improvement.
    Toy4X4[OP] and HuskyMike[QUOTED] like this.
  14. Mar 14, 2025 at 2:44 AM
    I was going with the clip adjustment.
  15. Mar 17, 2025 at 4:32 PM
    yep!
    2” lift Bilstein 6112 w/600 lb coils front, 1.5” lift Eibach T13 coils rear, Bilstein 5100 rear shocks, TRD skidplate, 285/70/17 Falken WP AT3, Energy Suspension front bumpstops, SSO Slimline Bumper w/ Badland Shackles, Durobumps 4.25” rear
  16. Mar 23, 2025 at 6:12 AM
    turbofrank
    turbofrank New Member
    Saturday
    Franco
    blacl on black 2020 trd offroad venture
    Awesome setup . Been looking at the spacers option but prefer going this route. How is the overall ride ?
  17. Mar 23, 2025 at 9:19 AM
    Thank you!
    i love the ride. Each year I travel from Pa to Nc on a 1 way 10-12 hr drive and it perfect for me and my 3 passengers, No complaints during that 1000 mile round trip.
  18. Mar 23, 2025 at 11:24 AM
    BoiseG
    BoiseG New Member
    2024 ORP
    I have the 6112/5100 setup. Mine is set to clip 6 on front, which raised it 2.7" and I used the Bilstein 1" lift spring in the rear. The spring part number is 36-281817. I opted against the 5160 rear shocks because they only come with a 2 year warranty and a reputation for leaking. Both the 6112 and 5100 have a lifetime warranty. I also have 285/70 tires. It's not quite level, it has just a small rake.
  19. Mar 23, 2025 at 11:32 AM
    turbofrank
    Saturday
    Franco
    Thanks for your input and reply. Just trying to gather as much information and reviews before going with a setup. Greatly appreciated. There's so much out there, don't want to regret my purchase.
  20. Mar 23, 2025 at 1:33 PM
    turbofrank
    Saturday
    Franco
  21. Mar 23, 2025 at 1:36 PM
    TxTRD
    TxTRD New Member
    Tx
    22 TRD ORP
    Every time I see this I think to myself I should have gotten Ice Cap. Gold looking rig.
    BoiseG[QUOTED] and djwantke like this.
  22. Mar 23, 2025 at 1:49 PM
    its the 600 lb/in coils that came with the 6112 kit. B12 load coil maybe
  23. Mar 23, 2025 at 3:47 PM
    i found it in my pics
    turbofrank[QUOTED] likes this.
  24. Mar 23, 2025 at 4:00 PM
    BoiseG
    BoiseG New Member
    2024 ORP
    Thanks! The reason I chose white was because I have a black 2001 Tundra and it never looks clean so I didn't want anything dark. haha
  25. Mar 23, 2025 at 4:33 PM
    RepentOrPerish
    RepentOrPerish New Member
    4thGenv8
    I have 5100 shocks and moog coils in the rear.. i feel its too soft, if i put a 150lb or so in the back the front wanders on bumps. Plan to get heavier coils, but torn on what spring and weight to go with.
    turbofrank and TrailSpecial22 like this.
  26. Mar 23, 2025 at 4:55 PM
    T13 coils is what in run. 13% stiffer than stock + 1.5” lift. Really nice when you need to load up the rear.
  27. Mar 23, 2025 at 5:22 PM
    RepentOrPerish
    4thGenv8
    Doesnt look like t13 coils will work on my 2006 for whatever reason.
  28. Mar 23, 2025 at 5:30 PM
    will a t12?
  29. Mar 23, 2025 at 5:40 PM
    RepentOrPerish
    4thGenv8
    Does look like t12s fit 4th gen.
  30. Mar 24, 2025 at 7:42 AM
    andrewtheadventurer
    Super white II - 040
