Advice for pressure-washing underbody?
Discussion in 'General 4Runner Talk' started by xmt037, Aug 13, 2021.
  1. Aug 13, 2021 at 5:00 PM
    xmt037
    xmt037 [OP] New Member
    2021 ORP
    ARB Skid Plates, FrontRunner SlimLine2 rack, 31" KO2s
    I took my ORP offroad the past few weekends and it's pretty darn dusty underneath. Is this something a pressure-washer (the $150 home depot electric kind) could help with? And if so, anyone have any tips of things to definitely avoid pressure-washing (cushings and gaskets, for example)? Thanks!
  2. Aug 13, 2021 at 5:26 PM
    Mtbpsych
    Mtbpsych New Member
    Dusty or muddy? If it’s just dust I wouldn’t even waste time personally, it’s going to be a never ending thing if you go off-roading often. But if you have to than any regular pressure washer can do the job.
  3. Aug 13, 2021 at 5:57 PM
    xmt037
    2021 ORP
    Mostly dust, but it's a fairly thick layer (California dirt roads are incredibly dusty due to the heat + volume given winter rains). Just wondering how safe it is to let it build up like that and a pressure-washer seems like a good investment.
  4. Aug 13, 2021 at 7:57 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Unless you live by the Sultan Sea, California dust don’t rust.
    7385, PhantomTweak and xmt037[OP] like this.
  5. Aug 13, 2021 at 8:50 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Maybe a little safer, compressed air will do the job on dust pretty nicely. Perhaps a little more difficult to get the nozzle into the tight spots, but you don't have to worry about water intrusion. Given that you may need to get closer to get the nozzle where you need to, a decent dust mask, like for painting, and some good safety glasses, would be a good idea.
    I lived in Yuma, speaking of the Salton Sea, for nearly 30 years, so I got real familiar with dust from off roading! Out at work, we made a wand for our air system. Normal squeeze handle, but a 3 foot section of metal tubing, similar to brake tubing, on it instead of just the little nozzle thingy. Let us clean the undersides of vehicles with ease, without having to crawl under them. No dust mask needed, but safety glasses required.
    Alternatively, maybe just a garden hose with a regular garden hose nozzle is adequate for dust. Don't have to get quite so close to get the nozzle where you need it, and since it's low pressure water, it will keep the dust out of the the air. No dust mask. You'll still need safety glasses though.
    Have fun!
    Pat☺
    Toy4X4 and 7385 like this.
  6. Aug 13, 2021 at 11:58 PM
    BeavertonCommuter
    BeavertonCommuter New Member
    Somehting like this - https://www.mtmhydroparts.com/produ...1hrpttZf91JvQUfJEWzALpECCe9OKu4BoCIvgQAvD_BwE
  7. Aug 14, 2021 at 5:07 AM
    JerryC
    JerryC New Member
    2021 Venture
    There's guy on YouTube, the Detail Geek, that pressure washes the underside of every vehicle he details.
    He goes fast so the pressure washer doesn't linger in any one spot. Check out one of his videos and you'll see.
    Also, one of the car washes near me has a pressure wash that comes on as you drive into the wash bay. I've used that many times with no problems on other vehicles.
    interceptor likes this.
  8. Aug 14, 2021 at 4:42 PM
    Charlievee
    Charlievee New Member
    Wear eye protection. Just saying.
    Captain Spalding likes this.
  9. Aug 14, 2021 at 4:58 PM
    I just use a regular hose to get mud off. I’ll also use the jet option of my garden nozzle to spray inside the holes in the frame until water runs out of every hole. I usually put the front on ramps, then rear, to clean everything out real good. But I’m. usually soaking by the time im done.
    Daddykool and Oldtoyotaguy like this.
  10. Aug 14, 2021 at 6:40 PM
    Daddykool
    This is probably better than pressure washing. You’re interested in a good rinse, not in forcibly removing everything that the high-pressure stream can dislodge. Some pressure washers will remove or damage undercoating or paint. Don’t do that.
  11. Aug 14, 2021 at 8:53 PM
    JerryC
    JerryC New Member
    2021 Venture
    As a general rule, there's risk in everything if you don't know how to do it. Educate yourself on proper technique and equipment and then decide.
    One of the great things about pressure washing is you get enough force to remove debris by using much less water. Less water can also mean less damage.
    If you use a pressure washer on your paint and it's fine, you aren't going to hurt the paint on the frame. If you could blast off the undercoating with the same pw that you wash the car with, it wasn't adhering properly and will likely have rust behind it.
    There are ways to adjust the amount of pressure, there are simple inline regulators and you can change nozzles to reduce the pressure.
    Lastly, with a water broom sitting on the ground there is enough clearance between the nozzles and the vehicle so that you are going to lose impact pressure as the pattern widens.
    If/when you are using a wand you can do the same by just moving the nozzle away from the surface you are cleaning.
  12. Aug 15, 2021 at 4:40 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    $5 bucks in quarters (redundant) over at the local self service car wash with pressure washer wand, is what I use.
  13. Aug 17, 2021 at 12:50 AM
    dricko
    dricko New Member
    Derick W.
    Using a garden sprinkler is a cheap yet effective solution.
  14. Aug 30, 2023 at 10:57 AM
    Yoda_Mike
    Yoda_Mike New Member
    Michael
    South Glens Falls, NY
    2019 Toyota Tacoma TRD Sport
    I know this is an old thread, but in case anyone comes across it, searching for a similar solution, this device works well for undercarriage washes.
    11" WATER BROOM - RYOBI Tools
    It fits most standard pressure washer wands. Also works well for cleaning sidewalks and driveways.
