ADS coils leaking - hose or fitting malfunction?
Discussion in '5th Gen 4Runners (2010-2024)' started by Thacrow, Oct 23, 2022.
  1. Oct 23, 2022 at 4:31 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
  2. Oct 23, 2022 at 4:34 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Interesting... I hope those fittings are not made by AeroQuip. Not sure if there is a safe way to remove that hose and leak check it under pressure on the bench. Or at a hydraulic shop.
    Thacrow[OP] likes this.
  3. Oct 23, 2022 at 4:47 PM
    Thacrow
    2021 ORP
    Speed holes
    Poor quality brand ?
  4. Oct 23, 2022 at 4:49 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    They were famous for leaking. They are / were an aviation brand back in the day, but I had AeroQuip fittings on some heavy equipment I operated for a time in the late 80s. Looks similar to what is in the photo.
  5. Oct 23, 2022 at 6:30 PM
    See if ADS will send another or order it. You'll have to relieve the nitrogen pressure from the reservoir before removing the hose and charge it back up when you're done.
  6. Oct 26, 2022 at 3:30 PM
    Thacrow
    2021 ORP
    Speed holes
    I've sent them a couple emails and nothing back.
    I'm past what is probably a 1 year warranty.
    I'm very sure this was my fault. When initially installed the springs kit the hose when compressed and I quickly adjusted the hose. Pretty sure the force of those hits caused this.
