Adding OEM Power Running Boards to a ‘16 Limited
Discussion in '5th Gen 4Runners (2010-2024)' started by LimitedBuild, Aug 11, 2023.
  1. Aug 11, 2023 at 7:24 PM
    LimitedBuild
    LimitedBuild [OP] New Member
    Hello
    I just picked what I consider to be a near perfect spec Limited; White over Redwood, clean, one owner. But it didn’t come with the power running boards like I wanted. Is there a way to add these OEM or aftermarket? I don’t want to remove the side skirts on the Limited.
    Thank you
    mtnslyr likes this.
  2. Aug 11, 2023 at 7:52 PM
    RetiredTRDowner
    RetiredTRDowner 2022 TRD Off-road Premium
    Fain
    Bella Vista, Arkansas
    Tint windows, replaced valences (black), 3x2 READYLIFT, Black Rhino Abrams (olive green) wheels, 185/70/17 Falken Wildpeak AT3 tires, AMP Power Running Board
    I installed AMP POWERSTEP RUNNING BOARDS on my ORP
  3. Aug 12, 2023 at 4:20 AM
    LimitedBuild
    Thanks for that - it appears these won’t work with the Limited because of the side rockers
    dbrad1985 likes this.
  4. Aug 13, 2023 at 6:16 AM
    dbrad1985
    dbrad1985 New Member
    From what I've researched I can't find any aftermarket running boards that work with the limited trim.
  5. Aug 13, 2023 at 4:30 PM
    steelevo
    Utah
    No sure that you can find or install automatic OEM boards. They are a factory installed option and not a port installed option.
