Add-a-fuse (fuse tap) and circuit questions - Does orientation matter? Circuit explanations?
Discussion in '5th Gen 4Runners (2010-2024)' started by j2runner, Nov 15, 2022.
  1. Nov 15, 2022 at 11:22 AM
    j2runner
    j2runner [OP] New Member
    I recently installed raptor lights (4Runner lifestyle kit) on my 22 TRDP.
    When I first installed them, I just directly followed 4RL's tutorial video. When it came to installing the fuse tap, I popped it into the 10A "Tail" slot, with the fuse block pointing toward the front. This worked, and the tail circuit is nice, as the raptor lights seem to follow other exterior lights.
    After doing some research online, I learned there's a correct way to orient a fuse tap - with the left side of the tap being powered by 12V. After checking with a multimeter, I found that the way the video instructed put the tap in backwards. The "Tail" circuit is in the corner and there's no room to have the tap flipped, so I moved it to the "KDSS" fuse (KDSS isn't present in the TRDP, but the fuse is there). Ideally, I'd like to be able to move the fuse tap back to the Tail circuit, or to a headlamp circuit, if one is present here.
    I looked at the back of a Littelfuse tap box, and the instructions state (paraphrasing) "plug it in. If the accessory doesn't work, flip the direction" - which implies it's not a big deal. My understanding is that if it's reversed and the main (lower) circuit spikes, both circuits will lose power. If the secondary (upper) circuit spikes, only the secondary circuit will lose power.
    With all this said, does the orientation really matter for low power accessories?
    I plan to add a couple of other things that will require 3 additional fuse taps (2 circuits for compressor button + 1 circuit for dashcam), and I'm stumped on which circuits I'll use.
    Is there a guide online that explains each circuit? Which circuits are always-on, which work only when the vehicle is on, etc?
    I've seen guides for prior models, but my 22 model seems to have different circuits (see attached photo).
  2. Nov 15, 2022 at 11:51 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    I doubt it really matters but maybe there is someone who can make a finer distinction.
    Though I do have 3 fusetaps installed and never gave much thought to orientation. It's been years with no issues.
    Just depends on how you want them powered.
    Do you want them only powered when the key is in ACC mode or engine running?
    Or do you want to be able to power them even if the engine off - battery powered.
    I would choose ACC accessory power as you don't have to worry about forgetting about leaving things on and potentially draining your battery. But also depends what you are trying to accomplish.
  3. Nov 15, 2022 at 12:41 PM
    j2runner
    Thanks, that's reassuring!
    I think I'll move the raptor lights back to the "Tail" fuse - as mentioned, I like that the lights go on/off with the rest of the head/taillights.
    For the compressor button, there are two circuits:
    1. Button lighting - ideally, ACC mode. Is there a circuit that gets controlled with the rest of the dash lighting? (I.e., only turns on at night/when headlights are activated)
    2. Relay activation - this should only come on when the engine is running
    I think my dashcam may have a mode where it can record when the card is off, so I may want this to be plugged into an always-on circuit (I think the hardwiring kit comes with a circuit that monitors input voltage and stops draining the battery when it crosses a low threshold)
    Which would be good candidates for these?
  4. Nov 15, 2022 at 1:26 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    The fuse tap orientation does matter. If you orient it the wrong way you will be drawing current from the “output” of the OEM fuse (and it’s load) and not directly from the battery +12V. Your additional load current (to the raptor lights etc) will be going through both fuses instead of one. In the case of an overload of your lights the lower value fuse will generally blow first, but not always. The OEM fuse may be overloaded and blow more often. It’s not really a good practice to do this.
    See the diagram below.
  5. Dec 8, 2022 at 6:28 AM
    j2runner
    Bumping this thread w/ another question - does anyone know the difference between the three IGN fuses?
    I assume "IGN" means these are all ignition-controlled? Wrapped up my compressor installation yesterday, but put the isolation/relay lead on an ACC-controlled circuit (for some reason, "KDSS" is ACC controlled), and I don't want to risk the compressor being enabled without the engine
    Of course I'm fine testing the circuits to confirm they're ignition-controlled, but I want to make sure I'm not tapping into any mission critical circuits
  6. Dec 8, 2022 at 1:30 PM
    swingbatta
    swingbatta New Member
    2020 TRD ORP
    Following this closely. I’m in the process of installing a SwitchPros 9100 in my 2020 ORP. I need to use an add-a-fuse to the “tail” and “acc” fuses, and have the same issue. The “acc” fuse is fine but there’s no room to properly orient the add-a-fuse in the “tail” slot.
    Of all the install videos I’ve watched, none of the installers seem to test the fuse slot before putting in the add-a-fuse.
  7. Apr 5, 2023 at 12:47 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I haven't tried TAIL or ACC yet, but I found engine bay IGN slot tripped my ecu and lit up dash warning lights when I added piggy fuse holder (perhaps I was plugged in reverse polarity that time? I just learned from electroboy above).
    YouTube dash switch video recommends interior fuse box open slot between #13/14. But I tested no voltage there. I actually successfully tapped multiple 12v loads into open slot above #4, which has acted the same as IGN for me!
    Edit: I see now from OP newer fuse box covers show my fuse slot actually labelled as 10A IGN NO.2 so there ya go!
    Old Tanker likes this.
  8. Apr 12, 2023 at 9:42 PM
    Kimo
    Kimo New Member
    2021 4runner nightshade
    I am using IGN No 2 for my raptor lights to be always on. I am not very good with electricity. Is using IGN No 2 unsafe? If so , would you recommend another fuse to keep the raptor lights always on?
  9. Apr 12, 2023 at 9:46 PM
    Kimo
    Kimo New Member
    My fuse box
