Actual height on a front 2” level kit =3”?
Discussion in 'Suspension' started by Cormy, Jan 25, 2022.
  1. Jan 25, 2022 at 9:13 PM
    Cormy
    Cormy [OP] New Member
    Looking at all the threads on the level kits, I get the general impression after installing a 2” level spacer on top of the strut, the actual lift will be 3” due to the new geometry of the suspension parts.
    thanks for you attention.
    Toy4X4 likes this.
  2. Jan 25, 2022 at 9:28 PM
    Mtbpsych
    Mtbpsych New Member
    No, a 2” spacer gets you 2”.
    Cormy[OP] likes this.
  3. Jan 26, 2022 at 8:13 PM
    Cormy
    I dont know, watched a few install videos and when they measured, it was higher than 2"..??
  4. Jan 26, 2022 at 8:18 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    So depending on what you are doing you could be a little higher at first. Your car will take a few days/weeks (depending on how often you drive) to settle. If you measure after that you should be around 2”. Again it all depends but generally speaking 2” is 2”.
    Mtbpsych likes this.
  5. Jan 26, 2022 at 8:31 PM
    Mtbpsych
    Mtbpsych New Member
    This happens with suspension lifts where coils and springs may take some time to settle after install, as mentioned by @GrantA.
    Maybe there’s some hidden science I’m not aware of though.
  6. Jan 26, 2022 at 8:31 PM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I did a 2” cornfed spacer kit and got 2” of lift. But, the provided spacer I put in between the coil spring and top hat was not 2”. I don’t think it even equaled two inches when combined with the spacer above the top hat, but I could be wrong.
    It sounds like you’re trying to say that putting a 2” thick spacer inside the strut will equal more than 2” of lift, which may be true, but from what I’ve seen, most 2” spacer kits only lift 2”.
  7. Jan 27, 2022 at 6:44 AM
    Cormy
    Ok, makes sense..we'll see...just ordered a 2"/1" level kit from Rough Country.
  8. Jan 31, 2022 at 11:13 AM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    An advertised 2" spacer usually means you'll get 2" of lift, not that the spacer is 2" thick. It's usually a 2:1 ratio of thickness to lift height.
  9. Feb 13, 2022 at 11:52 PM
    This is how it works.
