Ac issues
Discussion in '1st Gen 4Runners (1984-1989)' started by Jmhayes780, Jul 15, 2024.
  1. Jul 15, 2024 at 12:12 PM
    Jmhayes780
    Jmhayes780 [OP] New Member
    2nd gen 4Runner
    None yet
    Good morning. Bought my first 4Runner today gen 1 1986
    I have two issues I’d like help troublshooting.
    1. I turn the ac on and it makes a sound but no air comes out?
    2. anyone know how to install a aftermarket stereo into these?
    thanks so much guys.
  2. Jul 16, 2024 at 2:48 PM
    Beneeets
    Beneeets New Member
    Benito
    1986 4Runner
    None yet.
    Nice! Just bought my first 4Runner as well, also an 86!
    Did you check the blower, located under the glovebox? Mine was filled with crap and was barley pushing air, cleaned it out and works good now.
    As for the stereo, I haven't upgraded mine yet but I used to install car audio and security. Does it still have the factory system? Pocket or no pocket? Depending on what you have, you may need a dashkit. You'll definitely need a wiring harness to connect to the factory plug, you'll wire this to the new stereo of your choice. Crutchfield is a great resource.
    Powerstroke likes this.
  3. Jul 16, 2024 at 3:33 PM
    Jmhayes780
    2nd gen 4Runner
    None yet
    How do I get to it to clear it out and what does it look like lol. Sorry I’m not super mechanically inclined.
  4. Jul 16, 2024 at 3:51 PM
    Beneeets
    Beneeets New Member
    Benito
    1986 4Runner
    None yet.
    All good. If you look under the glove box you'll see a cylindrical object with a plug at the bottom. There are three screws that hold it up in there. If you undo those screws you can pull the blower cage out, that's where all the junk will be, if there's any in there. You don't need to remove the glovebox, but it does help a little. Let me know if you still can't find it, I can send photos later when I get home.
    Jmhayes780[OP] and Powerstroke like this.
  5. Jul 16, 2024 at 6:36 PM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Blower looks clean
  6. Jul 16, 2024 at 6:58 PM
    Beneeets
    Beneeets New Member
    Benito
    1986 4Runner
    None yet.
    Ok. You said “it makes a sound”, what exactly does this sound like? Does it sound like the blower motor is running? Or does it just make a single click, like a relay?
  7. Jul 16, 2024 at 7:24 PM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Blowers def not running I turn it on and it sounds like a buzzer or something.
  8. Jul 16, 2024 at 11:37 PM
    Beneeets
    Beneeets New Member
    Benito
    1986 4Runner
    None yet.
    Is it just when the AC button is pushed in? Or whenever you turn the fan on? Sounds like you might have a bad relay. Usually the relay behind the dash will make a "click" noise when you change the fan position (Off-low-med-high). But if it's buzzing it sounds like the relay might be getting stuck.
  9. Jul 17, 2024 at 6:02 AM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Ya it just changes pitch when I press the ac button. Is the dash pretty simple to remove?
  10. Jul 17, 2024 at 9:09 AM
    Beneeets
    Beneeets New Member
    Benito
    1986 4Runner
    None yet.
    I don't think removing the dash is necessary. I'm not sure exactly where your buzzing noise is coming from, but I would just remove the panels/trim around the fan/AC controls and radio, which is simple enough. You'll also need to remove this to replace your stereo anyways. It's been a minute since I've removed these panels, but I believe you need to remove the fan and vent knobs (just pull them off) to pull that small rectangular piece off, there should be some screws behind there. Just be gentle and take it slow, and use plastic panel popper tools! You can buy a set of those on Crutchfield as well, probably Amazon too. They'll come in handy when removing any type of panel or cover that you don't want to damage.
  11. Jul 20, 2024 at 10:59 AM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Ok so it’s the relay. I replaced it still no power getting to the blower. Maybe the blower motor is shot?
  12. Jul 31, 2024 at 4:17 PM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Finally got a can but now when I go to put the ac on the buzzing is coming again from that relay. Started doing it the other day but I turned it on and off really fast a few times and the fan came on.
  13. Jul 31, 2024 at 4:24 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Sounds like a seized up blower motor
    Jmhayes780[OP] likes this.
  14. Jul 31, 2024 at 5:02 PM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    Regarding stereo, go to Crutchfield. The will tell you what fits and how to install it.
  15. Aug 1, 2024 at 11:41 AM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Not the blower motor.
    I can feel the relay like vibrating when I turn it on physically and audible
  16. Aug 1, 2024 at 12:03 PM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    That relay is bad when it chatters like that. Replace it. They are not expensive.
  17. Aug 1, 2024 at 12:33 PM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Just put a brand new one in nothing
  18. Aug 1, 2024 at 12:41 PM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    We are talking about the AC - does the blower work when you turn it on without the AC? Say with heat or defrost? And what is the relay labeled that you replaced?
  19. Aug 1, 2024 at 12:42 PM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    It would be labeled on the underside of the box cover.
  20. Aug 1, 2024 at 1:29 PM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Fingers crossed I found the issue. The resistor is destroyed. Corrosion broken points etc. ordered a new one will keep you guys informed
  21. Aug 2, 2024 at 8:27 AM
    Jmhayes780
    2nd gen 4Runner
    None yet
    Relaxed the resistor. Fan comes on now but it’s really weak
