AC comes out hot. 1990 3.0L
Discussion in '2nd Gen 4Runners (1990-1995)' started by rabidvajer, Jun 7, 2021.
  1. Jun 7, 2021 at 9:08 PM
    rabidvajer
    rabidvajer [OP] New Member
    1990 v6 4runner SRT 4x4
    Hey 4Runner family
    When I turn on the AC in my 1990 3L 4x4, the air comes out HOT. In Southern California, So I'd like to get this fixed before it gets any hotter. Any suggestions on how I can begin solving this? Thanks!
  2. Jun 7, 2021 at 9:41 PM
    AdmiralNoodle
    AdmiralNoodle New Member
    Quin
    2021 sr5 premium 4x4
    Is there any change in the way the airflow sounds switching from hot to cold? If it's coming out hotter than ambient, sounds like the blendoor in your hvac ducting isn't moving properly
  3. Jun 8, 2021 at 11:11 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Either take it in to have it checked out to see what the issue is or try to recharge it yourself but make sure you change the Schrader valves out when you do it.
  4. Jun 8, 2021 at 12:16 PM
    KRUPP
    KRUPP New Member
    1991 Toyota 4Runner, 3.0, 4wd
    None yet
    I'm having a similar issue with the AC on my '91 w/3.0. I ordered some R12 replacement refrigerant on Ebay in hopes that solves it. We'll see in a few days.
    Trlhiker: Please expand on your schrader valve replacement comment.
  5. Jun 8, 2021 at 12:35 PM
    AdmiralNoodle
    Quin
    Personally the store storebought ac recharge kits don't sit well with me, I've had several customers use them and kill their systems. They have stop leak in them usually, which can sometimes clog the components.
    As far as changing the valves, I wouldn't say it's necessary, and if your system has refrigerant in it, you'll have to clear that out before removing the old valve.
    On top of that, you'll fill your system with air, which has to be evacuated before recharging with refrigerant.
    A simple ac service shouldn't cost too much at a local shop, I recommend starting there so they can use the right equipment
  6. Jun 8, 2021 at 1:10 PM
    KRUPP
    KRUPP New Member
    None yet
    Thanks Admiral.
    I didn't like the idea of stop leak in there either. My issue is that around here, all the shops I called don't work with/carry R12. So, you're kinda stuck with converting to the newer 134 (I think), or using R12 or the equivalents.
  7. Jun 8, 2021 at 2:03 PM
    AdmiralNoodle
    Quin
    Yeah I've been there too, when I had my old miata. I switched to 134a, ac worked good enough for a convertible haha
  8. Jun 8, 2021 at 2:44 PM
    rabidvajer
    so I put the AC on full blast, and shift the tab left and right from cold and hot. I don't notice a change in the sound or airflow.
  9. Jun 8, 2021 at 3:52 PM
    AdmiralNoodle
    Quin
    And no change in temp when switching?
    One other thing to check, I believe in 90 the trucks still used heater valves to control heat to the cabin. An in line valve on your heater hose under the hood, controlled by a cable/linkage. Make sure that moves with the temp knob on the hvac
  10. Jun 8, 2021 at 4:32 PM
    rabidvajer
    Yea. No change in temp. Hot hot hot.
    I'll look into the heater valve. Thanks for the suggestion
  11. Jun 8, 2021 at 4:49 PM
    AdmiralNoodle
    Quin
    Yeah sounds like heater valve or something in the ducting, let me know what you find.
    Good luck!
  12. Jun 8, 2021 at 7:32 PM
    trlhiker
    trlhiker Lazy Bum
    Where you hook up the recharge to each port is called a schrader valve much like on a bicycle tire. The internal piece is what will possibly need to be replaced. It is recommended that when you recharge a system, that internal valve should be replaced.
  13. Jun 10, 2021 at 10:05 AM
    ZARTT
    ZARTT New Member
    Art
    1995 4Runner, Black,Tan Interior, 5spd.,(convert from A340) 207,000 mi., on its 3rd 3VZE.
    Ford Taurus 2 spd. elec. cooling fan, GM CS-144 alternator upgrade. Intimidator AGM battery.
    Hi:
    It is pretty impossible to DIY repair an A/C system legally, and successfully, in any vehicle, without the proper tools.
    You must first determine if then system is even turning on. Start the engine, let it warm up, and turn on the A/C with vents set the way you usually like them.
    Raise the hood and watch the A/C compressor with the engine at idle. You should see the compressor clutch cycle on, and off for a set time period.
    If this is not happening, then the refrigerant quantity is too low for the compressor to activate.
    This is a fail safe feature, so the compressor doesn't destroy itself trying to pump an empty system unlubricated.
    This will also tell you that you most likely don't have a problem with the venting that directs the airflow under the dash.
    If you change out the valves in the low, and high side pressure pipes (as some posters suggest) the system will bleed out what ever refrigerant is in it, and you have just made the job more expensive.
    If the refrigerant is R-12, it is totally illegal to vent this substance to the atmosphere. It must be captured
    I have serviced countless HVAC systems in all types of vehicles going back to Roman chariot days, and have never heard of a situation that required changing the Schrader valves in the ports.
    Have the A/C system checked and serviced by a reputable shop, with the proper tools and equipment for capturing any refrigerant bleed off.
    They will ensure that you have a leak free system that will last for years.
    And best of all you get a guarantee.
    Good Luck
    Art
    AdmiralNoodle likes this.
  14. Jun 10, 2021 at 1:21 PM
    KRUPP
    KRUPP New Member
    None yet
    Hey Rabidvajer.
    Received the refrigerant recharge kit today and recharged the system. Was very low on pressure, like around 6-7lb. Added one can to get it to about 31lb. Could have used a bit more, I think. But that meant puncturing another can and only using part of it, even though the guy says the stuff is enviro-friendly.
    Temp in center vent runs at about 39-43d now going down the road. Not arctic-like, but good enough and I don't want to push the old system too much more.
    Think that was an easy fix. We'll see how it holds.
    This is what I used... https://www.ebay.com/itm/122508929925
  15. Jun 10, 2021 at 9:56 PM
    ZARTT
    ZARTT New Member
    Art
    Hi:
    There are two major reasons not to DIY refill your A/C system with what is sold as R-12, and R-134 compatible refrigerant.
    1.) The substance is a mix of propane, and isobutane, and in the short term can provide as a substitute for either of the original refrigerants.
    BUT, the gas molecule of the substitute is much smaller than the others, and, given enough time, will slowly leak past the O-rings, causing them to deteriorate,and leave the system empty.
    2.) The substance when mixed with oxygen, forms a highly explosive gas, that just needs a point of ignition to cause all kinds of havoc.
    I'm not trying to be a scare monger here, but chemistry is chemistry, and nothing can change that.
    Art.
  16. Jun 15, 2021 at 1:08 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    If you are checking for a leak in the A/C system, I agree with trlhiker, do not assume the Schrader valves are not leaking. If you still have some pressure in the system and have an electronic sniffer remove the dust caps and it will let you know if there is a leak. If you don’t have a sniffer, a few drops of soapy water will show a leak. The last two vehicles I worked on with A/C problems, the only leaks were the valves. One of the vehicles took 2 new valves on the high pressure side to get a valve that did not leak.
  17. Jul 11, 2023 at 3:56 PM
    Anandez661
    Anandez661 New Member
    Tony
    1990 4runner 22re
    Nothin Special
    I actually have been ticking around about it on my car I’m not sure if you’ve fixed it but if you e gone ahead recharged and rebuilt it (which I think you should regardless) it sounds like your AC Blower Motor resister has gone out. Make sure to get under there and church your blower too it’s looks like a cold air intake filter thing but it’s a fan and it’s located behind the dash on the right side it’s the rounder shaped box. Check it by hand and see if it’s spinning okay and then with it plugged in see if it turns on when you flip the blower switch to check if it’s making sound when on and clean if necessary. If it dosent spin or speed up when you change the speed from what I’ve seen it’s the resister I have yet to try and fix it though
    2ndGen22re likes this.
  18. Jul 11, 2023 at 4:04 PM
    Anandez661
    Tony
    1990 4runner 22re
    Nothin Special
    I’ll post again when I try it out for whoever reads this forum in the future for help…
