ABS, Slip indicator, 4x4 indicator light (flashing). All 3 just came on.
Discussion in '5th Gen 4Runners (2010-2024)' started by Atlantic 4runner, Feb 19, 2023.
  1. Feb 19, 2023 at 12:02 PM
    Atlantic 4runner
    Atlantic 4runner [OP] New Member
    Tim
    2019 4Runner
    3” struts, light bar, fog lights. Lots of dog hair.
    So the ABS, Slip indicator and 4x4 (flashing) indicator lights just came on. I can’t put it in 4x4, the ABS won’t engage, and I can burn rubber! Haven’t done anything unusual, gone off road, or even engaged the 4x4. I am driving up a snowy/sandy/salty Maine dirt road, but nothing any other vechicle can’t handle. I’m thinking it’s some kind of sensor or perhaps a fuse. Any advice would be appreciated.
  2. Feb 19, 2023 at 12:58 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: LFD and Bud Built. Tires: KM3. Switchpro.
    Split a paperclip in half so you have two 90 degree conductors, and execute a zero point calibration. If you do it yourself it will take a few minutes. If you take it to a dealer they will charge you for two hours of 4WD diagnostics.
    steelevo likes this.
  3. Feb 19, 2023 at 7:09 PM
    Foothills
    Foothills New Member
  4. Feb 27, 2023 at 3:43 AM
    Atlantic 4runner
    Tim
    2019 4Runner
    Took it to the shop and they plugged in the computer. It shows up as a "wheel speed sensor" and/or a "wheel bearing" issue.
    Turns out the speed sensor wire was broken and causing the warning. I spliced the wire and I'm back on the road.
    Thanks all for your help!
  5. Mar 2, 2023 at 4:07 PM
    Thanks for updating with your solution. Could you tell where and how that wire got damaged? And is it the same one as the ABS sensor?
    Acou and grizzlypath like this.
