ABS/DSC LIGHT AND WARNING BUZZER??
Discussion in 'General 4Runner Talk' started by daddymac, Aug 18, 2016.
  1. Aug 18, 2016 at 11:44 AM
    daddymac
    daddymac [OP] New Member
    kevin
    2003 4 runner limited v8
    none
    ANY HELP WOULD BE APPRECIATED! my 03 limited V8 4 runner
    is down right now due to what appears to be an ABS braking problem.
    a lexus mechanic used a scan tool the codes come back to the Brake actuator and accumulator pump ( cant drive as the brake pedal is rock hard )
    has anyone fixed this problem ??
    what was the cause?
    I'm told a new complete unit with Master cylinder and acc/pump is around 2700.00
    a new accum. pump alone is 1600.
    and a used from ebay between 500-700
  2. Sep 2, 2017 at 8:48 AM
    JediMind76
    JediMind76 New Member
    2001 4Runner SR5
    Hello, I am having this exact issue, where you able to resolve the problem? I believe its the brake booster portion that is faulty. I will attempt to locate one at the junkyard today, like you said every piece in the ABS/Brake booster assembly is very expensive.
    I know there is a special tool needed to bleed this system once anything is replaced and the lines are exposed to air.
