ABS disable
Discussion in '5th Gen 4Runners (2010-2024)' started by peter2772000, Feb 27, 2022.
  1. Feb 27, 2022 at 5:20 AM
    peter2772000
    peter2772000 [OP] New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Hey guys,
    I want to install a switch to neutralise the ABS on my truck. I admit that my tires don't have ideal winter traction, even though they sport the mandatory snowflake emblem as required by this godforsaken province.
    Regardless, I simply want to disable it at will. I've scoured the site and have Googled this as well, nada.
    Thx
  2. Feb 27, 2022 at 7:25 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Why exactly?
    And can it be done? Not really. Its a safety feature that works with other safety features and is all run by a computer. Simply adding a "switch" isn't an option.
  3. Feb 27, 2022 at 9:27 AM
    You would probably get a ton of error lights going. But if there is an abs fuse that can be pulled, that would at least tell you how the computer would react to abs being shut off (do that at your own risk, I have no idea if this would cause problems).
    Are you doing this because the abs keeps pumping at super slow speeds causing you to be unable to stop? I had that happen to me once and it pissed me off. At slow speeds of 1 to 5mph, even most types of ice will give enough traction to stop with locked wheels faster than abs will allows. I felt stupidly helpless going 2mph, abs pumping away, as I rolled through a stop sign. I swear Ive driven smarter abs setups that know when to just keep the wheels locked at very slow speeds (in fact, I think our 18 highlander just keeps them locked).
    Hmm, I just thought of something…. I don’t remember if I had any steering angle in when it slid…could be the computer was prioritizing turning over stopping if I had wheel slightly turned.
  4. Feb 27, 2022 at 9:49 AM
    I think pulling the fuse and dealing with the dash lights like @McSpazatron mentioned might be the only way. I suppose you could splice in a switch.
    There's times I would prefer to not have it as well.
    peter2772000[OP] and McSpazatron like this.
  5. Feb 27, 2022 at 10:15 AM
    cuse93
    cuse93 Ice Station Zebra
    After just a few months of ownership, I have definitely noticed that the ABS on my 4Runner is very "aggressive". Much more so than on my past Tacomas and Tundras. Not sure that i'd want to completely disable it.....but I would like to tone it down a bit.
  6. Feb 27, 2022 at 10:46 AM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
  7. Feb 27, 2022 at 12:39 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Wouldn't turning off ABS cause 4WD problems? Specifically 4LO?
  8. Mar 2, 2022 at 3:26 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
  9. Mar 2, 2022 at 9:27 AM
    beankozi
    beankozi New Member
    Jarrett
    Vancouver Island
    2021 Venture
    quite a few
    glad I could help! please report back once you get it installed. this is something that I'm planning on doing as well.
  10. Mar 4, 2022 at 8:46 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    ABS is turned off in 4 low.
    2Toys[QUOTED] and BionicRandy like this.
  11. Mar 4, 2022 at 9:17 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Dr KDSS has an elegant solution to disable ABS, although kind of expensive for what you get. (He does have decent directions on how to access the 4WD control module).
    You can achieve the same thing without a relay, only a switch.
    Here’s a discussion:
