95 Toyota 4Runner 3VZE 5 Speed manual
Discussion in '2nd Gen 4Runners (1990-1995)' started by 808WannabeCarGuy, Sep 7, 2022.
  1. Sep 7, 2022 at 2:26 PM
    808WannabeCarGuy
    808WannabeCarGuy [OP] New Member
    Salvador
    1995 Toyota 4Runner
    I bought this 4Runner a few months back and the seller stated that the vehicle was “running rough”. I bought it thought it might’ve been a faulty or clogged throttle body but after changing that the vehicle no longer has enough power to shift into 2nd or 3rd without the rpm going too high. I tweaked the throttle body screw a bit to see if anything would change but I’ve got the same results or it just stalling on me.
    Has anyone on here experienced this problem?
  2. Sep 9, 2022 at 11:32 PM
    1ino
    1ino New Member
    Lino
    1994 Gold 4Runner
    removed running boards
    Nope.
    did you do a compression check, did you check the condition of the spark plugs, If these engines are prone to blowing head gaskets, is it running rough because of coolant in the cylinder causing the plugs to not fire.
    Hope to see you on the trail.
