95 sr5 idle and running trouble
Discussion in '2nd Gen 4Runners (1990-1995)' started by Beaver94, Apr 17, 2022.
  1. Apr 17, 2022 at 12:53 PM
    Beaver94
    Beaver94 [OP] New Member
    Jeremy
    1995 4runner sr5 3.0
    Small lift 33 inch tires
    Just bought a 1995 4runner sr5 3.0 auto on 33s cranks right up no hesitation everything works ac heat very nice imo but has a couple little issues when driving it has zero power lol barely makes it to 40mph on level ground and only about 50 downhill trans shifts fine doesn’t overheat no check engine light and now it’s wanting to idle a little high imo idk around 1500-1700 any ideas can’t really dump a lot of money into it atm but love everything else about it thanks yall
  2. Apr 18, 2022 at 7:30 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Idle should be around 800. There is a screw that you can turn to adjust it on the left hand side of the engine. A tune is also in order as are fluid drains and fills. Start with that.
    Beaver94[OP] likes this.
  3. Apr 18, 2022 at 8:22 AM
    Beaver94
    Jeremy
    Trlhiker it just had a full service fluids plugs cap everything and it was doing the same thing before I changed all that stuff
  4. Apr 18, 2022 at 10:11 AM
    Low power but high idle?
    Vacuum leak?
    and/or
    Weak Fuel Pump?
  5. Apr 18, 2022 at 11:03 AM
    Beaver94
    Jeremy
    I checked for vacuum leaks with starting fluid never changed nothing would a bad fuel pump cause that issue ?
  6. Apr 18, 2022 at 11:31 AM
    Doubleduty
    3rd gen ltd and 5th gen SR5
    Clogged or very dirty Cat Converter? :notsure:
  7. Apr 18, 2022 at 11:56 AM
    Beaver94
    Jeremy
    It’s already been taken off for a while so no issues there
  8. Apr 18, 2022 at 12:36 PM
    Doubleduty
    For your sake, I hope it's not, however, it could be worn lobes on the camshaft. I hate to reference a Chevy, but I had an old Malibu once with a 305 motor that developed the same symptoms and that's what it turned out to be. Probably NOT your problem, but it just got me thinking. The 305 was notorious for it.
  9. Apr 18, 2022 at 3:47 PM
    Bad fuel pump will not make power. It can allow a car to idle but not make power.
    You said the cat is removed? This car has an ECU, right? How does it deal with no CAT or O2 sensor?
    Beaver94[QUOTED][OP] likes this.
  10. Apr 18, 2022 at 4:25 PM
    Beaver94
    Jeremy
    It does fine no check engine light been deleted for a while
  11. Apr 18, 2022 at 6:42 PM
    OBD1 or OBD2?
  12. Apr 18, 2022 at 7:22 PM
    Beaver94
    Jeremy
    It’s obd1
  13. Apr 18, 2022 at 7:41 PM
    Ok, if no codes, no vacuum leak, no cat, my gut would say, it's going to be in the intake\injectors\ecu.
    I would focus on the power issue more than the idle. Might still be a transmission issue.
    Can it go 40MPH in reverse?
  14. Apr 18, 2022 at 7:52 PM
    Beaver94
    Jeremy
    Not sure haven’t went that fast in reverse lol
