91' 4 Runner burping sound when drops to idle
Discussion in '2nd Gen 4Runners (1990-1995)' started by Rooster1313, Nov 24, 2021.
  1. Nov 24, 2021 at 1:49 PM
    Rooster1313
    Rooster1313 [OP] New Member
    Just completed timing belt, waterpump, etc replacement, have 330K miles. Replaced number of bad vacuum lines and old hoses. Runs good, but makes burping noise when it drops back to idle. Could that be a vacuum leak, or maybe air still in the coolant system? Sounds is coming from the back side of the engine, on passenger side...at least that's how it sounds.
  2. Nov 25, 2021 at 9:18 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I would say you got air in the coolant system somewhere.
    Rooster1313[OP] and LandCruiser like this.
  3. Nov 25, 2021 at 9:51 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    My 80 did this after I replaced the wp. Air bubble.
  4. Nov 28, 2021 at 2:04 PM
    Rooster1313
    Bleeding several times hasn't solved the issue and during a test drive, the vehicle is making very little power. I'm confident the timing belt replacement was done correctly with proper timing. Could replacing vacuum hoses have created a problem...maybe a failed component was getting "bypassed" due to split vacuum lines? We also put a new O2 sensor on...could that be throwing off the mixture? We ran the diagnostic and just get constant blinking. Any ideas would be much appreciated. Thx!!
    Also, adjusting the idle mix screw as very little effect.
