88 EGR Valve
Discussion in '1st Gen 4Runners (1984-1989)' started by bferrie, Jun 17, 2020.
  1. Jun 17, 2020 at 3:57 PM
    bferrie
    bferrie [OP] New Member
    Brian
    88 4Runner
    Struggling to locate an EGR Valve for my 88', 3.0L 4Runner. Am I going to have to run an EGR delete? If so, What can I expect?
    Thank you in advance...
  2. Jun 20, 2020 at 9:49 PM
    NightOwl
    NightOwl 1985 Toyota 4 Runner DLX 22REC
    Amos
    Ballwin, MO
    LCE header, 2.5 inch exhaust, 31x 10.50 BF Goodrich, 15 X 8 aluminum wheels, Bilstein Shocks, 3 inch lift kit, 3M fender flares
    I just plugged off my EGR years ago...I was getting an inconsistent miss on flat roads that irritated the crap out of me...so I just put a plug in the vacuum lead to my nice $89.00 new EGR that is currently just looking nice but my 1985 4 Runner doesn't skip a beat any more...weird!!!
    bferrie[OP] and MI-FL off roader like this.
  3. Jun 25, 2020 at 4:37 AM
    bferrie
    Brian
    88 4Runner
    Installed an EGR Delete kit from Yotashop the night before last. Much smoother and more powerful but not quite there. Still a little rough at idle so I'm hunting another vacuum leak... I hope!
    MI-FL off roader likes this.
  4. Jun 25, 2020 at 6:08 AM
    Dark Knight
    Dark Knight Get off my lawn
    Check the vacuum lines that go to the thermal vacuum valve to the evap canister. Many times that is broken because it’s plastic. it’s the blue one with two nipples on the left of that picture. One vacuum line goes to the evap canister, the other to the back side of the throttle body. Throttle body side is where you will be loosing vacuum.
    105550d1469159151-3vze-sensor-block-3vze_8378ee3211fb14731903778b0f4aafe2e74cff47.jpg
    bferrie[OP] likes this.
  5. Jun 25, 2020 at 9:01 AM
    bferrie
    Brian
    88 4Runner
    Good stuff! I'll apologize in advance... where is the Evap Canister located?
  6. Jun 25, 2020 at 10:00 AM
    Dark Knight
    Open the hood and look to the back left of the engine compartment. It’s black about the size of a soup can mounted on the firewall.
