.85" front lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Wbflyer, Oct 6, 2020.
  1. Oct 6, 2020 at 12:57 PM
    Wbflyer
    Wbflyer [OP] New Member
    Todd
    2020 4Runner TRD ORP
    none yet
    Getting ready to have this installed to take some of the rake out. Do you see any issues just doing a .85 spacer to the front? I do not want it perfectly level since I tow a light trailer. This should give some rake but not too much.
  2. Oct 6, 2020 at 1:17 PM
    D animal
    D animal New Member
    Dan
    2020 Nightshade
    I did a 1" spacer and I think it's perfect. I still have a bit of rake but it's not a drastic
  3. Oct 6, 2020 at 1:23 PM
    Wbflyer
    Todd
    none yet
    perfect!! You left the rear alone? "That's what she said" :)
    ThePnsh3r likes this.
  4. Oct 6, 2020 at 1:32 PM
    Wbflyer
    Todd
    none yet
    Ok, I think I need to have them do .5, not .85. Do you have a pic of your rig by chance? I think we are after the exact same thing.
  5. Oct 6, 2020 at 1:35 PM
    D animal
    D animal New Member
    Dan
    2020 Nightshade
    I went with the same spacer as beedee from cornfed. Just the front and it's exactly what I wanted.
  6. Oct 6, 2020 at 1:37 PM
    D animal
    D animal New Member
    Dan
    2020 Nightshade
    A .5" inch spacer will yield you 1" of lift. The spacer thickness is not the same as the amount of lift it gives so be mindful of this.
  7. Oct 6, 2020 at 1:47 PM
    Did the Eibach Pro Truck front struts (+ rear shocks with no lift), 2nd snap ring setting (.85), turned out great:
    I think I could have gone with the third snap ring setting (1.75) and also been fine, with just a bit of rake still...
    Kfish, A&P and SlvrSlug like this.
  8. Oct 6, 2020 at 5:19 PM
    D animal
    D animal New Member
    Dan
    2020 Nightshade
    Kfish likes this.
  9. Oct 7, 2020 at 7:22 AM
    The downside to doing a spacer on the front is that you extend your stock struts, which will reduce your down travel (but increase up travel). This can shorten the life of your stock struts if you're frequently bottoming them out.
    The better option is to purchase some Bilstein 5100s or Eibach Adjustable front struts. They have a setting where you can add 0.85" of lift to the front. They accommodate for that increased height by offering a longer strut so you won't bottom out as easily.
    A 0.85" lift in the front with 0" in the back will give you the look of a stock PRO. You'll still retain some factory rake for towing, hauling, ect.....
    Kfish and A&P like this.
