6th Generation thoughts of mountain driving
Discussion in '6th Gen 4Runners (2025+)' started by edogcooter, Apr 20, 2024.
  1. Apr 20, 2024 at 4:37 PM
    edogcooter
    edogcooter [OP] New Member
    What are the initial thoughts about the 4 cylinder and how well it may do in the mountains? I live in Colorado and wondering if I should get the last year of the 5th generation or wait until the fall for the new one.
    ColoradoTJ likes this.
  2. Apr 20, 2024 at 4:50 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Being a turbocharged engine, it should do very well at elevation. The 5th Gen is the epitome of reliability and the 6th Gen reliability is unknown at this point. There are people of faith in Toyota and believe the 6th Gen will be reliable. Time will tell if this is true or not.
    Harringbr99, MEski4x4, BS67 and 3 others like this.
  3. Apr 20, 2024 at 5:54 PM
    icebear Recovered Kia Owner
    The T24A-FTS has been used in the Tacoma, NX, Highlander, etc. since 2021/2022ish and hasn’t been causing trouble yet. We will see how it does long-term but for now it seems alright.
    it’ll probably be a better experience at elevation as mentioned.
    Harringbr99 and Thatbassguy like this.
  4. Apr 20, 2024 at 6:03 PM
    engineer90
    engineer90 New Member
    NJ
    At elevation it should do even better than the 5th gen. Them turbos are super helpful in thinner air!
    MEski4x4 and Thatbassguy like this.
  5. Apr 21, 2024 at 5:28 AM
    COTacoPro
    COTacoPro New Member
    Taco Pro; previously 4Runner Pro
    It’s already been said but in terms of power, it won’t even be close. Naturally aspirated engines lose about 15-20% at elevations of 5k ft vs sea level. To have the turbo will be to recapture the power loss.
    With respect to reliability, you know the 4.0 V6 on the 5th Gen is really reliable. It’s a proven motor and very very simple by modern standards but also is quite inefficient though under stressed. It’s interesting to read about the same population of fervent Toyota supporters who swear their allegiance to the brand because of their conservative approach to product development, R&D and durability testing, simultaneously say how the new engine is gonna be a dumpster fire and unmitigated disaster. While it’s def a more complicated engine, if someone is gonna make sure it’s hearty and reliable, it’s Toyota. They wouldn’t gamble the franchise (Landcruiser, Tacoma and 4Runner are legendary brands unto themselves). Toyota knows why people buy Toyotas… stubborn reliability and resale value as a consequence. This is a turbo motor engineered as a Toyota turbo motor from inception. It isn’t a naturally aspirated 4 cylinder they then strapped a turbo to like people are making it sound. The compression, cylinder wall pressures under boost, heat generation all have been considered. Not to mention the state of modern materials and metallurgy that also allow for reliable motors with technical specs not possible a decade or two ago.
  6. Apr 21, 2024 at 6:49 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    TL;DR:
    It won't be as reliable as the 1GR (no modern engine likely will be again), but it shouldn't be unreliable.
    OP: everything that can be said here is speculation. Check the 4th Gen forum on Tacomaworld in about a year for real information.
    Pavo likes this.
  7. Apr 21, 2024 at 6:55 AM
    Besides the turbo performing better at elevation, it also has more torque at a lower, usable range which will noticeably improve driving mountain grades.
    Thatbassguy and Trail Runnah like this.
  8. Apr 21, 2024 at 7:54 AM
    Pavo
    Pavo New Member
    bruh the Tacoma in 21 has a 2trfe 2.7 na NOT the 2.4 turbo (unknown and unreliable) 4th gen Tacoma engine (2024)
  9. Apr 21, 2024 at 7:55 AM
    Pavo
    Pavo New Member
    Or check out the 3rd gen tundra forums (v6 turbo) where it’s a 3 year old platform and the bearings are still failing on brand new models at 20k miles)
  10. Apr 21, 2024 at 8:01 AM
    ColoradoTJ
    ColoradoTJ I drink...and I know things. Staff Member
    Chris
    The problem was human caused and resolved. If you have a 2023 mid year or newer...GTG
  11. Apr 21, 2024 at 8:06 AM
    It’s new in the 2024MY Tacoma but what I mean to highlight is that it has been put in the 2022MY (2021 production) NX and 2023MY (2022 production) Highlander before that and hasn’t been blowing up Hyundai/Kia-style yet.
    (not to mention the RX, Grand Highlander, etc. but those are also newer)
    I’m sure there will be changes between transverse, longitudinal, gas-only and hybrid applications but so far I’d say no news is good news.
    Thatbassguy and Schlappesepple like this.
  12. Apr 21, 2024 at 8:17 AM
    ColoradoTJ
    Chris
    We almost purchased a NX300 for the wifes daily. That 4CT moves that Lexus pretty good. You live just north of me about 20 minutes, so this will help you out a bunch. At ~6200 ft of elevation (I am at 7550') you will lose around 18% (3% for every 1000' elevation) with a NA motor and around 6-7% with a turbocharged motor.
  13. Apr 21, 2024 at 8:38 AM
    COTacoPro
    I’m surprised it’s even 6-7% given the way turbos work. If they boost on the basis of PSI and you have thinner air, they just cram more of the thinner air into the engine until that same boost pressure is achieved…. To an extent. Obviously there is an inflection point where it’s not necessarily possible for them to spin up and spool to shove as much thin air in and you’re shy of the desired boost/air (oxygen) to make the stoich work out optimally for the air/fuel.
    How much does a pound of thin vs thick air weigh… one pound is the answer… just more of the former to reach one pound.
    Perry1060 likes this.
  14. Apr 21, 2024 at 8:57 AM
    ColoradoTJ
    Chris
    Atmospheric pressure, air density, and turbo selection. Not all turbos work great in all applications. Car manufacturers have to tune and select a turbocharger size for 0-14000' of elevation. The oem's could select a turbo that works well at 6000-14000' but would be total ass at sea level. Make sense?
    Thatbassguy and icebear like this.
  15. Apr 21, 2024 at 11:54 AM
    Schlappesepple
    2020 ORP
    Not the same engine = more speculation
    2005-2006 4.0 Tacos had systemic head gasket failures. Is that relevant?
  16. Apr 21, 2024 at 12:19 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    It might be the best 4runner yet. The turbo like Tacoma is supposed to be commercial grade. Probably better differential gearing and more transmission gears should make power better, but a hybrid is what you want for towing. Parts commonality with Tacoma and Land Cruiser should make them cheaper and more dependable.
    nimby and Thatbassguy like this.
  17. Apr 21, 2024 at 12:43 PM
    It's unknown, but somehow it's already unreliable?
    What does a different engine in a different vehicle have to do with anything?
    nimby and Stoney Ranger like this.
  18. Apr 21, 2024 at 12:56 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I am soooo glad I got my 2019. I would certainly kill a 4 banger turbo, especially since Turbos don't normally last much passed 150k in general.
    Perry1060 and Rob41 like this.
  19. Apr 21, 2024 at 3:38 PM
    Noodles
    Noodles New Member
  20. Apr 21, 2024 at 3:39 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    It will drive with more power than the 5G. Our Subaru ascent with the 2.4l turbo(wrx engine) is waaaayyy more powerful than the 5G.
    The subbie driving up the initial incline on i70 or 285 from Denver is effortless, rpm around 3k for keeping up with traffic or passing, during that initial climb
    the only unknown is longevity, compared to the 4.0 v6
    Perry1060 and ColoradoTJ like this.
  21. Apr 21, 2024 at 4:22 PM
    Noodles
    Noodles New Member
    Really? I had a Volvo 850 with original turbo at 260k miles. A 3 cylinder smart car 650cc with turbo and had 130k miles with original turbo. Not to mention the old turbo diesel Mercedes-Benz engines.
  22. Apr 21, 2024 at 4:27 PM
    Noodles
    Noodles New Member
    Why only Americans worry about this? I used to live in Switzerland and Austria but nobody purchased a car based on elevation. People used whatever they had. For sure snow tires and chains are mandatory but rarely saw a V6 engine vehicle on the mountain. Mostly 1.4 and 1.6 liter 4 cylinder.
    ColoradoTJ[QUOTED] likes this.
  23. Apr 21, 2024 at 6:49 PM
    ColoradoTJ
    Chris
    Not sure what the argument is here?
    I was talking about a 4 cylinder turbo (4CT).
    Most people do just use "what they have" unless they are looking for something new. This is the time to buy what is best suited for your next purchase.
    Let's be honest. Most European countries have small displacement cars (and size). Hell, the last time I was in Germany and Austria I took my BIL's BMW M car over the family vehicle due to size (and performance).
  24. Apr 21, 2024 at 7:34 PM
    233k and counting on the original turbo in my '07 Volvo. Owners typically get over 300K on them.
    4banger turbo is going to be quicker than the 4.0, especially at elevation.
  25. Apr 22, 2024 at 7:17 AM
    Ripper238
    2019 TRD OR
    Yeah, generally turbos need a little more maintenance too. Not to say you can't get 200k+ on a quality Turbo like from Volvo, but generally they are not going to go 300k.
  26. Apr 22, 2024 at 7:55 AM
    What extra maintenance do turbos require?
    People worship the 2UZ, and I would consider a t-belt replacement every 100k a lot more maintenance intensive than a turbo.
    nimby, icebear, Noodles and 1 other person like this.
  27. Apr 22, 2024 at 8:09 AM
    Noodles
    Noodles New Member
    Turbo needs no maintenance. Change the oil at 5-6k miles and don’t floor it when it’s cold. After heavy towing or uphill run let it idle for a minute. That’s it.
  28. Apr 22, 2024 at 8:12 AM
    Ripper238
    2019 TRD OR
  29. Apr 22, 2024 at 2:46 PM
    4R777
    4R777 New Member
    to recap engines w/turbos
    1. In cold environments, give engine time to warm up the oil.
    2. If you must drive right away, don't floor it. Keep RPM down.
    3. More importantly than warm it up, cool it down. Keep engine on 1-2m after you get to destination.
    4. Air Filters need to be watched more closely. More air/dirt gets sucked in by turbos and go through more air filters than traditional engine.
    5. Drive smart, not hard. Don't be driving high RPM, high load, all the time. Keep RPMs down, especially if you have a manual. Always be in a lower gear.
    No way most everyday city drivers going to do all this. Lol
    Ripper238[QUOTED] likes this.
  30. Apr 22, 2024 at 2:52 PM
    Noodles
    Noodles New Member
    Every day city drivers only encounter point 1. They won’t tow or do a racetrack day.
    The guy explained exactly what I said about turbo engines.
