5thGen4Runner - TPMS Digital Display
Discussion in '5th Gen 4Runners (2010-2024)' started by 1xAlpinex2, Jul 19, 2024.
  1. Jul 19, 2024 at 3:31 PM
    1xAlpinex2
    1xAlpinex2 [OP] New Member
    2014 Toyota 4-Runner (Trail w/ KDSS) - Nautical Blue
    — Remote Start Vehicle Mod — Interior Cargo/Hatch Control Switch: Rear Window & Unlock Mod — Hatch Lights (LED Upgrade) — Interior Lightbulbs (LED Upgrade) — Cargo & Hatch Molle Panel installs — Console Safe Install + — Sherpa Creatone (Full-Length) Roof Rack w/ Molle Panels both sides — Greenlane Hatch Ladder — TRD Style Grill Reppacement + — Icon Stage 1 Lift — Icon Alloy Rebound Wheels (17”) — 275/70R17 BFG-KO3’s + — Alpharex Nova Headlights — Diode Dynamics SS3 Max (Yellow) Fogs — Baja S8 40” Combo Lightbar (White)
    Hello! -- I have a 2014 4-Runner and my car did not come with a digital display option for Tire Pressure Readout. Does anyone know if there is a way to do this/ mod for this, etc. (?)
    I just got new tires and wheels put on, and new TP-Sensors put in. But no way of knowing their pressure unless I manually check.
  2. Jul 19, 2024 at 3:35 PM
    I believe a scangauge will display but I went with a Luxious Auto display in a switch blank. In this pic I have it in the lower left blank where the heated wheel button goes but I haven't relocated due to lazyritious. Also it's blurry because I still have the protective film on it.
  3. Jul 19, 2024 at 8:07 PM
    UATahoe
    UATahoe New Member
    Joseph
    Huntsville, AL
    2024 TRD Pro
    That’s pretty dang slick. Has it worked well for you so far?
  4. Jul 19, 2024 at 8:14 PM
    scottiezilla
    scottiezilla New Member
    Recognized n confirmed across the board
  5. Jul 22, 2024 at 11:08 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I also suggest scanguage 2. It will read out many real time parameters. I keep mine set for tire pressure and can see 4 tires at glance. Also can read tranny temp.
    I put a dab of paint on each valve stem : white, red, blue, yellow and have a post it with color to TP1,2,3 4 and a FR, FL, RR, RL pencil note and up date when tires are rotated. I used tire pressure guage to figure out which wheel is the TP1,2,3,4.
  6. Jul 22, 2024 at 11:35 PM
    Yeah no issues besides me forgetting to setting rotation when I do it. Also no real way to silence the alarm permanently until you fix the issue. This will be a pain when I air down.
  7. Aug 22, 2024 at 6:26 PM
    1xAlpinex2
    @whippersnapper02 — I just got the luxious switch in. Do you know where I need to plug the power into exactly(?)
    (See photo). Not sure what to do / where it goes…
    2014 4Runner (trail)
  8. Aug 22, 2024 at 7:51 PM
    Any switched 12 volt power. I believe I used the ignition circuit.
