5th Gen Stereo - Is there a Carplay Bluetooth adapter that works?
Discussion in '5th Gen 4Runners (2010-2024)' started by DesertEnjoyer, May 28, 2024.
  1. May 28, 2024 at 10:14 AM
    DesertEnjoyer
    DesertEnjoyer [OP] New Member
    Hey y'all. New member here. Did my best to search the forums on this subject before posting.
    I just got a 5th Gen and purchased this adapter to enable bluetooth Carplay connectivity. I have had frequent problems with it in the following ways:
    1. Volume level cannot be controlled when using Carplay.
    2. Phone sometimes does not automatically connect. (not as frequent)
    #1 is the biggest issue and is very annoying. Restarting the stereo or unplug/replug the adapter will fix this most of the time but that is not a viable solution for me as I plan to use this car for many years and this is super annoying to me.
    TLDR: Often can't control volume with OTTOCAST BT adapter.
    Q: Does anyone have a Carplay adapter that works 100% of the time?
    Q: Does anyone know of a permanent fix for these issues?
    Thanks in advance y'all. Stoked to be here on the forum.
  2. May 28, 2024 at 12:57 PM
    HuskyMike
    HuskyMike New Member
    I have that adapter and experience similar issues. It works well enough that I probably won't change it, but will be watching this thread to see what others use.
    Re: Volume issue- I can control the volume for the radio and Sirius just fine. If I switch to Apple Music or Pandora, I can't.
    I also wish it would control Siri and the radio independently like our Subaru. I don't think that's an Ottocast issue, though. I think that's a Toyota Carplay issue.
    JChiz and DesertEnjoyer[OP] like this.
  3. May 28, 2024 at 1:26 PM
    PJSnow
    PJSnow New Member
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    I purchased the AutoSky Pro adapter (https://autoskyus.com/products/autosky-wireless-carplay-adapter-pro) a while back. No volume issues but I do experience a delay when changing songs and on phone conversations. It is quite annoying and I have reverted to answering my phone on speakerphone. Every post on the forums surrounding the wireless carplay adapters seems to reference an issue with each one. Hopefully someone chimes in with an option that doesn't have issues...
  4. May 28, 2024 at 1:34 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I upgraded my head unit so i may not be remembering correctly. But i thought i could just run it through the BT in the stock head unit?
  5. May 28, 2024 at 7:25 PM
    Static03
    Static03 New Member
    Jacksonville Florida USA
    2021 Silver TRD Offroad
    Bilstein 5100's, 1" Cornfed Rear Spacer, Aluminum Skid Plate, Powerstop Z23 Pads/Rotors, 4WDKING 30" Light Bar, Nilight Ditch Lights, BBG4x4 Front Recovery Points, American Outlaw Gunslinger wheels 17x8.5 -6 Offset with Toyo Open Country AT3's
    Cable apple car play/android auto only for us 4runner guys. I went with a Motorola unit for Android auto. Works perfectly. Not sure if they make an Apple version.
    Ripper238[QUOTED] likes this.
  6. May 29, 2024 at 8:55 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    SEPA
    2023 PRO
  7. May 29, 2024 at 10:35 AM
    adamant365
    adamant365 New Member
    2024 Underground SR5P
    I've been happy with my Carlinkit 5.0 as well. It works 99% of the time on my '24. The 1% of the time it doesn't connect, I simply unplug it and plug it back in and it will connect then. I did have an issue with volume controls becoming unresponsive after I updated the Carlinkit firmware, but I simply downgraded to the previous firmware and it's been working fine since. It does take 15-20 seconds to connect but once it does it's rock solid. I also occasionally get a very brief stutter, but I think that's the stock head unit's fault. It only ever happens when the head unit switches from camera mode back to CarPlay. I have my 360 camera set to come on automatically at slow speed since it makes parking so much easier.
    I have a right angle USB adapter so that I can tuck it in the otherwise useless bottom center dash cubby.
    Edit...for clarity.
  8. May 29, 2024 at 7:38 PM
    Grimble27
    Grimble27 New Member
    WA
    2024 SR5
    DesertEnjoyer[OP] likes this.
  9. May 30, 2024 at 9:48 AM
    FastEddie6
    FastEddie6 New Member
    Eric
    2023 TRD Off-road
  10. May 30, 2024 at 10:54 AM
    DesertEnjoyer
    Thanks for the advice y'all. I just purchased the Carlinkit 5.0 and will report back if that works better. Hopefully I can talk OTTOCAST into giving me a refund if so.
  11. May 31, 2024 at 2:23 AM
    ThatGuyTheCooler
    SEPA
    2023 PRO
    I have one in my Tundra, and one in the 4runner. Both 100% no issues with connecting. Just remember, connect your phone's bluetooth to the carlinkit unit, not the vehicle.
  12. May 31, 2024 at 7:38 AM
    Welcome. I used the carlink adapter when we had our Venza. Was great, laggy, but no connection issues.
  13. May 31, 2024 at 8:18 AM
    HuskyMike
    For what it's worth, after upgrading my iphone from and 11 Pro Max to a 15 Pro, I can now control the audio in Pandora (haven't tried Apple Music yet). While the volume issue was relatively new- I know I could control it at some point with the Ottocast- I don't know if it was the phone switch or just coincidence. I ordered the Carlinkit to try out too.
  14. Jun 4, 2024 at 4:52 PM
    Papa G
    Papa G New Member
    2024 TRD ORP Classic Silver
    I just bought this one https://www.amazon.com/dp/B0CN9VDDVP on Amazon. I had the Carlinkit 3 in my Tacoma. It worked for the most part and the updated Carlinkit 5 was on my radar but opted for this one based on reviews. I don't know how it stacks up against the Carlinkit 5 but it connects fast and works flawlessly...so far. If it continues to work I will buy another for the wife's RAV4.
  15. Jun 4, 2024 at 8:39 PM
    TRDGrey2021
    TRDGrey2021 Guy in a truck
    2021 TRD Venture MGM
    Buncha Stuff
    I have a Carlinkit4.0 which works mostly well.
    Cannot adjust volume of carplay...annoying.
    Sometimes has delays.
    MOST ANNOYING, reboots when it wants to and on long trips, it will sometimes just lock up (though I fixed that by 3d printing a case with a fan to cool it...IT GETS HOT)
    Also, from, time to time, it just stops, disconnects and will not accept phone connection. I think due to whatever app is open on the phone.
    As a result, I am close to pulling the trigger on a kenwood head unit, though going from the 8 in factory unit to a 7 inch is something I have to wrap my head around.
  16. Jun 5, 2024 at 10:12 AM
    beedee
    beedee Member
    Will that work with a 2018 4Runner?
  17. Jun 5, 2024 at 11:50 AM
    DesertEnjoyer
    Update on this thread: I've been using the Carlinkit 5.0 for about a week and it seems much better.
    - No longer having issues controlling the volume.
    - Connecting is fast and pretty stable.
    - Stereo interface is much more responsive/faster.
    TLDR: If you're having the same issues on a 5th Gen 4Runner. Go for the Carlinkit 5.0 it works great.
    adamant365 and ThatGuyTheCooler like this.
  18. Jun 5, 2024 at 12:05 PM
    Papa G
    Papa G New Member
    It should work in any vehicle with wired CarPlay.
  19. Jun 5, 2024 at 12:13 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    I spent a bit more and went with a multimedia box. Does Android Auto/Apple Carplay wirelessly and a lot more!
    https://techwizard-mmb.com/
  20. Jun 5, 2024 at 3:51 PM
    HuskyMike
    Just got mine today and hooked it up. I'll report back after a week or so of using it.
  21. Jun 7, 2024 at 8:15 AM
    Manhattan
    Manhattan New Member
    The CarLink is on sale right now. I guess it's a Fathers' Day sale - $169 (not that it's ever really that much) on sale for $64.99... then a 20% (code: Dad) additional discount, and free shipping. I bought one and will report back.
    ThatGuyTheCooler likes this.
  22. Jun 7, 2024 at 12:49 PM
    Bburn
    Bburn New Member
    2024 TRD PRO Underground
    I just ordered the CarLink 5.0. Using the promo code Dad it was $57. I will also post some updates on how it performs in the coming weeks.
  23. Jun 13, 2024 at 2:16 PM
    Snotties Dad
    Snotties Dad New Member
    2018 4Runner
    stock
  24. Jun 13, 2024 at 6:10 PM
    Ripper238
    2019 TRD OR
  25. Jun 13, 2024 at 7:58 PM
    HuskyMike
    Been using the Carlinkit 5.0 (2air) for about a week. Overall it functions like the Ottocast. I don't find it better or worse. The startup sequence is different than the Ottocast. It seems to start later in the overall media system's startup. Not a good or bad thing.
    It's restarted itself at least once for apparently no reason. All other audio functions perform as they should. Touch screen seems to function as quick/ smooth as the Ottocast.
    I had had a problem where the Siri audio would occasionally drop from Carplay and come through the phone. It would always reconnect itself. Thought that was the Ottocast, but the Carlinkit has done it a couple times too so it's probably a phone thing or general Carplay thing.
    One thing that happened on the Ottocast that has not yet happened on the Carlink is, intermittently, the steering wheel control to activate Siri would not work. I'd have to use the side button on my phone. It worked most of the time, but happened enough to annoy me. I think I've used the Carlink enough for it to happen if it was going to but so far so good.
  26. Jun 13, 2024 at 8:31 PM
    TRDGrey2021
    Buncha Stuff
    I have an Ottocast on the way.
    I have been using the Carlink4, and have not loved it. Reboots when it feels like, especially on long trips and use ( and I have a d printed enclosure with a cooling fan), cannot adjust carplay volume. Had to reload firmware once. I works..but it is not rock solid.
    I'll report back after I get the new unit, since it is my last option before replacing the whole head unit. I hope I do not see issue with Siri. @HuskyMike, which version did you get?
  27. Jun 14, 2024 at 5:54 AM
    PJSnow
    PJSnow New Member
    PJ
    New York
    One feature that I noticed not all of these adapters include, is the ability to input address/location while moving (Google Maps or Waze). The AutoSky Pro adapter allows my wife to use CarPlay while I drive, which I found to be an issue with one of the earlier Carlink units.
    Still hoping someone finds one that doesn't have issues and allows functionality while in motion.
  28. Jun 14, 2024 at 8:21 AM
    HuskyMike
    I should have made it more clear in my post (I've edited the post) that the Siri/ Steering wheel thing was an intermittent problem. It happened enough to annoy me, but worked most of the time.
    I got the U2AIR Pro Wireless CarPlay Adapter. Since I replaced my iPhone around the same time I switched carplay units, I can't say for sure the steering wheel button/ Siri thing was related to the Ottocast. I plan on switching back to it just to test it.
  29. Jun 14, 2024 at 9:24 AM
    TRDGrey2021
    Buncha Stuff
    I have this one on the way Ottocast
    We shall see
    HuskyMike likes this.
  30. Jun 14, 2024 at 10:40 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I'm not sure if CarPlay is the same, but that's baked into Android Auto. It will take voice commands but you have to be stopped for anything else, regardless of how you're connected.
