4x4 sPOD Wireless Units
Discussion in 'Lighting' started by bajadesigns, Apr 26, 2023.
  1. Apr 26, 2023 at 3:23 PM
    bajadesigns
    bajadesigns [OP] New Member
    Are you tired of fishing those wires through your firewall, cutting into preexisting wire loom boots, or drilling holes in your dash to mount a switch panel in the cab? Here at 4x4 sPOD, we felt it was time to eliminate those headaches and offer a fully Bluetooth unit for those who would rather have the luxury of running their accessories full of their phones and tablets. These options eliminate the headache of mounting the controller in the cab allowing more room for future mods and retaining that factory interior look.
    BantamX, Non-Switch Panel Systems
    The BantamX non-switch panel system is designed to be paired with the sPOD™ app on your phone or tablet, saving hours of wiring & installation time! It is a small, 8-circuit (expandable) control system that provides a clean and safe way to power and control 12/24VDC accessories. Due to the small footprint of the BantamX, the placement options are endless!
    Pair the BantamX with the sPOD app on your phone or tablet, you have a controller that can be used anywhere. Backed by sPOD’s 5-year manufacturer warranty*, stay in control with your sPOD™ BantamX control system.
    The 36” setups includes the following:
    • (1) BantamX System
    • (1) 36” Battery Cable Set
    • (1) Universal Mounting Bracket
    • All necessary hardware
    The 84” setups includes the following:
    • (1) 84” Battery Cable Set
    • 5-year Manufacturer Warranty
    Specs for the BantamX:
    • 8 circuits rated at 30 amps at 12.5 VDC per circuit
    • 16-position terminal block
    • 2 controller ports (RJ45) for Ethernet cables
    • Integrated low voltage cutoff battery protection w/ optional override
    • 100 amp in-line fuse
    • Operates on 12 VDC or 24 VDC
    • Built-in Bluetooth capabilities for remote control
    Configurations:
    BantamX, Non-Switch Panel, Uni w/ 36" Battery Cables | PN: 87-0114 MSRP: $604.95
    BantamX, Non-Switch Panel, Uni w/ 84" Battery Cables | PN: 87-0115 MSRP: $624.95
    Link: https://www.bajadesigns.com/products/spod-bantamx-non-switch-panel-universal/?sku=870114
    SourceLT, Non-Switch Panel Systems
    The SourceLT non-switch panel system is designed to be paired with the sPOD™ app on your phone or tablet, saving hours of wiring & installation time! It is a small, solid-state 6-circuit control system that provides a clean and safe way to power and control 12VDC accessories. Due to the small footprint of the SourceLT, the placement options are endless!
    Pair the Source LT with the sPOD™ app on your phone or tablet, you have a controller that can be used anywhere. Backed by sPOD's 5-year manufacturer warranty*, stay in control with your sPOD SourceLT control system.
    • (1) SourceLT System
    Specs for the SourceLT:
    • 6 circuits rated at 30 amps at 12.5 VDC per circuit
    • 12-position terminal block
    Configurations:
    SourceLT, Non-Switch Panel, Uni w/ 36" Battery Cables | PN: 87-0116 MSRP: $499.95
    SourceLT, Non-Switch Panel, Uni w/ 84" Battery Cables | PN: 87-0117 MSRP: $519.95
    Link: sPOD SourceLT, Non-Switch Panel - Universal - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
  2. May 8, 2023 at 1:51 AM
    ethan3456
    ethan3456 New Member
    Does this also required any other equipment or UTV Accessories to configure with it to get it's 100 percent work with the remote.
    bajadesigns[OP] likes this.
  3. May 9, 2023 at 5:06 PM
    bajadesigns
    No all you will need is a phone that will be your controller.
    Best,
    Brahian
