4x4 driving question.
Discussion in '5th Gen 4Runners (2010-2024)' started by QSL4runner, Nov 19, 2022.
  1. Nov 19, 2022 at 8:26 PM
    QSL4runner
    QSL4runner [OP] New Member
    Quentin
    4runner 2011 SR5
    Hey guys. So my name is Quentin from canada. I just bought a 2011 4runner. I switch to 4x4 for the first time 2 days ago and I have some issues. When I take a slow turn to the right or the left the truck slow down to a stop unless I stay on the gas almost sa if I was on the break.
    The truck came with 20" wheels instead of 17 and larger tyres. Could that be the reason?
    The dealership where I bought it told me it was normal ......
    Sorry about my poor English. I'm French and it's not always that easy to explain a situation.
    I hope somebody would be able to help me out.
    Stay safe
  2. Nov 19, 2022 at 8:32 PM
    You should not drive in 4wheel drive on the street. The owners manual explains the limitations when using 4wd. Also, there are warnings on the drivers visor you should review and follow
  3. Nov 19, 2022 at 9:10 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    It’s normal but it doesn’t mean it’s good. Only the limited can be a full time 4wd.
    On dry pavement, you want to stay in 2WD for all other trims
    utilise 4 roues motrices seulement sur des surfaces glissantes comme de la neige, de la boue, du sable, etc…
    Ne le fais pas sur une route normale à sec.
    s’il pleut beaucoup, ça peut aller tant que tu restes plus ou moins en ligne droite sans faire de tournants trop serrés
    2BEZ, ecoterragaia and Henry J like this.
  4. Nov 20, 2022 at 2:19 AM
    Welcome from Wisconsin! 2WD for the street, dry pavement, wet but not icy pavement, normal driving with good traction. 4WD on slippery conditions, icy pavement, snow covered conditions and where traction is poor, also when in 4WD limit speed, this can be addressed in the owner's manual. Good luck.
    2BEZ likes this.
  5. Nov 20, 2022 at 10:48 AM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    I agree 100%, well said. (I don't speak French, so there's that)
    semprenissart[QUOTED] and 2BEZ like this.
  6. Nov 20, 2022 at 10:51 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    Google translate says this is good advice.
    semprenissart and 2BEZ like this.
  7. Nov 20, 2022 at 12:23 PM
    QSL4runner
    Quentin
    4runner 2011 SR5
    Thank you guys for the quick answer. I had no idea but I won't do that mistake again.
    Dry 2wd
    slippery 4wd but slow
    grizzlypath, semprenissart and 2BEZ like this.
  8. Nov 20, 2022 at 12:27 PM
    QSL4runner
    Quentin
    4runner 2011 SR5
    So guys now that I know about awd conditions I ve an other question:
    Wich bullbars would you put on a 2011 sr5?
    Bolt on of course.
  9. Nov 20, 2022 at 7:28 PM
    semprenissart
    semprenissart Mèfi
    If it’s slippery you can use 4hi fairly fast. Just make sure you’re below 50mph (80km/h) when you activate it but after that you can go faster (not that you should go super fast if conditions are bad anyways)
    If you’re in 4lo then you want to go quite slow (think crawl mode). And to activate 4lo make sure you’re stopped and put the car in neutral beforehand.
  10. Nov 20, 2022 at 10:07 PM
    I've done the same mistake. Driven the entire highway in 4H. I noticed only when I took a turn to a local road feeling some hesitation. Then I switch back to 2wd. I think newer 4runner with smaller green 4wd indicators along with similar green headlight and fog light indicators doesn't give much attention. Older 4runner 4wd indicator gives little more attention. I don't feel anything wrong on mine, serviced twice after that and did not get any complaints from the techs. May be since the axles are not locked its not that big of a deal unless anyone ignore the hesitation and keep taking tight turns.
