4runner will not start
Discussion in '2nd Gen 4Runners (1990-1995)' started by Joseph4x4, Mar 16, 2019.
  1. Mar 16, 2019 at 4:38 PM
    Joseph4x4
    Joseph4x4 [OP] New Member
    1991 Toyota 4 runner 3.0 liter v6
    New long block installed in 12/2018
    I have a 1991 4x4 4 runner with a 3.0 liter v6 and manual transmission. I had a remanufactured egnine installed in December of last year. When I got it back the check engine light was on and giving a knock sensor code. The mechanic didn’t change it. My son has been driving it for the last 2 months and on the way home it just died and wouldn’t start back. Towed it home and checked fuel and it’s getting fuel but no spark. I changed the coil and the ignition control module and I still don’t have any spark coming from coil wire when turned over. I checked all the fuses. Anyone has any suggestions?
  2. Mar 16, 2019 at 4:46 PM
    Did you check the battery?
  3. Mar 17, 2019 at 11:26 AM
    Joseph4x4
    Yes and I did some more research now I have figured out, the rotor on the distributor is not turning when the engine is cranking. I suspect a broken timing belt which is only 2.5 months old or the distributor is broken which I didn’t replace when I replaced engine. Any reasons why this would happen?
