4Runner Stalking, er...um, SPOTTING with Charlie™ (5th Gen Edition)
Discussion in '5th Gen 4Runners (2010-2024)' started by PennSilverTaco, Sep 27, 2019.
  1. Dec 21, 2023 at 3:19 PM
    #571
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Please see signature!
    December 20th, 2023:
    Plumsteadville, Pennsylvania
  2. Dec 27, 2023 at 2:48 PM
    #572
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Maple Ridge, BC
    nice 5th Gen next to my 5th Gen @ the tire store
  3. Jan 2, 2024 at 8:34 PM
    #573
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    January 2nd, 2024:
    Doylestown, Pennsylvania
  4. Jan 23, 2024 at 5:43 AM
    #574
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2018 TRD Off-Road
    January 22nd, 2024:
    My neighborhood
    496550E8-DE49-4BA2-A24D-CD85B61BFBAD.jpg 9F52D783-DC94-4A2C-AE8A-91966D5C732F.jpg
  5. Jan 23, 2024 at 6:06 AM
    #575
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2011 SR5 with what appears to be a Lexus front clip!
    January 23rd, 2024:
    Denver, Pennsylvania
    B7C280C8-2591-408F-82F1-AB1381CF0A82.jpg C4D8D806-25EC-477E-B94E-209F23EB2F7A.jpg
    8A489B58-53AF-4B17-AFBD-552790890518.jpg 25C0C0F6-2644-431B-859A-50CD52193C67.jpg
    D3933C0F-B3AA-4727-93F7-7C708F26176F.jpg B102E31A-E8DE-46D3-ABB4-DCFF0D603F77.jpg
    michow87, icebear and Steve Berman like this.
  6. Jan 27, 2024 at 12:24 PM
    #576
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    January 27th, 2024:
    Warrington, Pennsylvania
    1BF66CFC-E46B-474F-B0CF-0B3C56E359DC.jpg 656C643E-CAAA-4A23-9C68-5A7CD7394B5F.jpg 1AA51FB3-FA4D-473B-BD0E-C626B863CDEA.jpg F401596F-32B6-447D-A366-64B08BB3C4F9.jpg
  7. Feb 4, 2024 at 8:09 PM
    #577
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2015 Trail
    February 3rd, 2024:
    Allentown, Pennsylvania
  8. Feb 5, 2024 at 6:47 PM
    #578
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    I've got a thread for 5th Gen T4Rs... :)
  9. Feb 18, 2024 at 2:05 PM
    #579
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2015 Limited
    February 18th, 2024:
    North Wales, Pennsylvania
    Harringbr99 likes this.
  10. Feb 18, 2024 at 2:08 PM
    #580
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2010 Limited
    Ambler, Pennsylvania
    9741DD9F-D3B9-45FF-A961-45CB8FA73A37.jpg 4CD5A1C7-0404-46EC-AB06-6E99B7F23F19.jpg
    06EA779C-E4C5-42CF-9C93-A2337D39942D.jpg FF55EF73-D450-4C3E-9CF8-526C7A5EA029.jpg
  11. Feb 18, 2024 at 2:34 PM
    #581
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    I normally do not make a big deal about seeing a 5th Gen Limited in the wild, as there are so many of them (and mostly in boring colors like black and white); I also do not normally make a big deal about lifted 5th Gens of ANY trim level if they are otherwise unmodified, but when I realized that was a lifted Limited, I had to get a pic because people rarely lift those from what I've seen. I saw the blue one in the parking lot of Shake Shack after picking up an Uber Eats order, and then I saw the gray one in the driveway of the customer I delivered that order too (he let me take pics)! As an added bonus, I also saw the silver 4th Gen in the Shake Shack parking lot...
  12. Feb 20, 2024 at 8:44 PM
    #582
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2013 Limited with 32K original miles!
    February 20th, 2024:
    Colmar, Pennsylvania
    6C89A80D-9917-4301-8066-27C60FFEF28A.jpg B35396CD-34F1-4012-8DB3-882F0E1954BB.jpg BD9EC69E-C642-4DD6-AB1F-6F3F432508FE.jpg 3E6B8E70-2311-4629-A095-EFDB79037344.jpg
    Harringbr99 and PrettyGoodSam like this.
  13. Feb 21, 2024 at 12:31 PM
    #583
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2021; Carfax says it's a "Venture"...?
    February 21st, 2023:
    5B548A0F-9566-481D-BD26-4EA00552FDAC.jpg 19DF7CF4-D419-45E6-8192-1A9EBD64D693.jpg AA0567B5-717F-4E37-A931-02113AF7D0D7.jpg 162AE62F-6700-4026-925F-82E79998E74A.jpg 8F897EB0-DE55-45C5-80A0-158FD29D746F.jpg
  14. Feb 22, 2024 at 11:45 AM
    #584
    Go Birds
    Go Birds New Member
    23 ORP
    Just when I thought that putting an M badge on a non-M BMW was the tackiest thing ever...
  15. Feb 22, 2024 at 6:09 PM
    #585
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    I only took pictures because it's unique and I'd never seen anything like it before; I'm not a huge fan, either...
    Go Birds[QUOTED] likes this.
  16. Mar 9, 2024 at 9:23 PM
    #586
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2012 Trail
    March 9th, 2024:
    Oaks, Pennsylvania
  17. Mar 9, 2024 at 9:31 PM
    #587
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    March 9th, 2024:
    Oaks, Pennsylvania
  18. Mar 10, 2024 at 7:00 PM
    #588
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2020 SR5 Premium with just 37K miles...
    March 10th, 2024:
    Hatfield, Pennsylvania
    D12A40B8-4A44-405C-84AC-6251EBC6090D.jpg F12A3578-A2C3-47CE-9D11-67DCDDAECAF3.jpg D15BADC9-2C70-4E8D-BAFF-869DC985D859.jpg F21D1782-D951-4111-84B4-9C53CCC1B5B6.jpg 92C0133F-1076-4698-BF6F-4299A5292E7B.jpg
  19. Mar 11, 2024 at 7:46 PM
    #589
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2022 TRD Off-Road
    March 10th, 2024:
    D78B817B-2204-4B51-BF78-467DF2AF7C4F.jpg 32D092DE-BB14-4F40-AA3E-A529269E38D9.jpg 3F6F3C4E-FA1D-4E20-B57B-19D78661C78B.jpg 78355E74-7FD0-486B-9EDE-A80D85B286E5.jpg
  20. Mar 23, 2024 at 8:35 PM
    #590
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2020 TRD Off-Road
    March 23th, 2024:
    Bethlehem, Pennsylvania
  21. Mar 25, 2024 at 11:49 AM
    #591
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    charlieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee I finally made it!!! :)
  22. Mar 25, 2024 at 6:53 PM
    #592
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    I don't hate it. I think if they got rid of the chrome accents and those window visors, it would look pretty good
  23. Mar 25, 2024 at 7:00 PM
    #593
    WTF!!! come on!!!!
  24. Mar 26, 2024 at 5:11 PM
    #594
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Were you at the Pet Expo?
    PrettyGoodSam[QUOTED] likes this.
  25. Mar 27, 2024 at 7:23 AM
    #595
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    yeah my search and rescue team always has a table there.
  26. Apr 1, 2024 at 8:06 AM
    #596
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Somebody already traded in a 2023 TRD PRO!
    March 31st, 2024
    Thorndale, Pennsylvania
    50680E3D-D1DD-434B-8603-538FB1E983AA.jpg 6E4F9B29-05DB-4F4E-A37D-70E22230763E.jpg 3527141D-A786-4AC4-AF27-47076F5DB5CD.jpg E680B0D5-7D7E-4B4E-A660-D8DAA6878271.jpg 5FEF6654-6D5E-4EC0-83C9-82525610B0D8.jpg 19658729-F5F4-4BA7-9301-4920BE90F5BE.jpg
    MEski4x4 and icestud like this.
  27. Apr 1, 2024 at 10:39 AM
    #597
    garoto
    garoto New Member
    Ooff! Unless they got tired of the color, can’t understand why.
  28. Apr 1, 2024 at 1:05 PM
    #598
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Could have had something else ordered and took this in the meantime. My father in law ordered his new F250 last year and the dealership sold him an F350 and told him to drive it for the year until it arrives and they will give him what he paid for it. Ended up giving him $6k more thanks to this ridiculous market.
  29. Apr 14, 2024 at 5:35 PM
    #599
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2023 TRD Off-Road
    April 12th, 2024:
    E1D22403-A4B4-4FD1-8307-E4687EAD8322.jpg 4DA80517-8D5D-46AB-AD0C-444A23A437BC.jpg 6E567231-5041-4FC5-8F88-16DEEE835219.jpg
  30. Apr 27, 2024 at 7:12 PM
    #600
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    They used a brand new Limited this year!
    April 27th, 2024:
