4runner Front Lift
Discussion in '5th Gen 4Runners (2010-2024)' started by ryannagaraj, May 1, 2023.
  1. May 1, 2023 at 8:02 AM
    ryannagaraj
    ryannagaraj [OP] New Member
    Ryan
    2021 4runner TRD Offroad XP Predator
    Hey y'all, I'm leveling my 4runner this month and wondering if I should get a 2-inch front lift or a 2.5-inch front lift. What are the benefits of each lift? I'm leaning towards the 2-inch one so it won't look as squatted. Thank you.
  2. May 1, 2023 at 8:08 AM
    I think 1 in is the difference to level. (I could be wrong)
    Eg -
    when I do 3in front and 2in rear my SR5 looked level.
    when I did 2.5in front and 1.5in rear my Limited looked level.
    when I added 0.5in to the factory 1in on my TRD Pro with zero lift in rear the front looks very slightly high, may be its just my eyes.​
  3. May 1, 2023 at 12:01 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    take base measurements on your truck and go from there.
    measure from the center of the wheel to the fender
  4. May 1, 2023 at 12:12 PM
    EC15
    EC15 ...
    That's too obvious and way more work then using the search function.
  5. May 1, 2023 at 6:54 PM
    afret
    North Idaho
    The wheel opening heights on the front and back are different. The back is higher so it makes the 4R look like it has a significant rake. Put a digital level on the frame to check. On my ORP if I get the wheel openings the same height, the frame would have a reverse rake.
    McSpazatron likes this.
