4runner Fog light Mod : Brite Box
Discussion in '5th Gen 4Runners (2010-2024)' started by irfan0922, Mar 2, 2022.
  1. Mar 2, 2022 at 5:46 AM
    irfan0922
    irfan0922 [OP] New Member
    The Brite Box – this will allow for all the lights (low beam, high beam, and fogs) to turn on all front facing 6 lights , but due to DOT regulations manufactures does not allow you to use fogs with high beams , by using this kit you will control your Fogs lights , by using this mod , you will get more visibility down the road with out adding extra lights . For this install, I chose to add the “Anytime” feature. This allows you to turn your fog lights on without the need to have your lights on. You can choose this option or the “Fogster” option if this isn’t something The install is much easier if you choose this Fogster option. Find it online: The Brite Box Anytime with OEM switch: https://www.aspireautoaccessories.com... use on web coupon .
  2. Mar 2, 2022 at 6:14 AM
    Ironguy New Member
    Looks interesting thanks for the tip:hattip:
    irfan0922[OP] likes this.
  3. Mar 2, 2022 at 6:18 AM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I've been looking into this mod. I find the LED hi beams almost useless on dark highways. I have Diode Dynamics fogs and they are great and would really help with the brights on.
  4. Mar 2, 2022 at 6:20 AM
    irfan0922
    @DallasTRDPro these are expensive fogs , Diode Dynamics are amazing fogs and this mod will bright up everything .
  5. Mar 2, 2022 at 6:22 AM
    DallasTRDPro
    Dallas
    I also find the stock LED low beams to just be whiter than the halogens. Not necessarily better.
