4gen maintenance suggestions
Discussion in '4th Gen 4Runners (2003-2009)' started by Hectorlowpe, Sep 2, 2021.
  1. Sep 2, 2021 at 10:37 AM
    Hectorlowpe
    Hectorlowpe [OP] New Member
    Phoenix, AZ
    2018 4Runner TRD Off Road
    Getting ready to hire a reliable mechanic to do a bunch of maintenance to my gen 4 V8 and was wondering if anyone has suggestions for me as to what I should have done other than what I already had planned. As of now he’s doing:
    - timing belt
    - coolant flush + thermostat
    - transmission fluid
    - spark plugs and spark plug wires
    - water pump
    Thanks!
  2. Sep 2, 2021 at 11:06 AM
    the_great_white
    the_great_white New Member
    How many miles?
    Hectorlowpe[OP] likes this.
  3. Sep 2, 2021 at 11:07 AM
    the_great_white
    If you're doing the trans fluid may as well go ahead and throw in the transfer case and diffs
    RonT4R and Hectorlowpe[OP] like this.
  4. Sep 2, 2021 at 11:23 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Without any information as to what might've already been done, all things to touch on a most likely 150k plus engine and drivetrain:
    -All that you mentioned
    -what Great White mentioned + wire mesh 'filter' behind trans oil pan
    -serpentine belt
    -power steering fluid
    -brake fluid
    -check brake pads, replace if needed
    -air filter
    -lube all zerks you can get your hands on for the drivetrain. your manual tells you what grease goes where
    -chassis grease on all the metal things rubbing against other metal things
  5. Sep 2, 2021 at 11:37 AM
    Hectorlowpe
    Phoenix, AZ
    255k
    Right on I’ll have the differential fluid changed too.
  6. Sep 2, 2021 at 11:41 AM
    Hectorlowpe
    Phoenix, AZ
    Previous owner only had the vehicle for about two months and all he did was engine oil and replaced all brake pads.
    I do my own oil changes and did that less than 1k miles ago. I do see a worn out sticker in the engine bay that says timing belt was changed at 90k miles and unknown if it has been changed since so obviously getting that done.
    Thank you for your suggestions!
    iamincrediboy[QUOTED] likes this.
