4 wheel drive
Discussion in '5th Gen 4Runners (2010-2024)' started by teddy4x4, Nov 21, 2024.
  1. Nov 21, 2024 at 5:39 PM
    teddy4x4
    teddy4x4 [OP] New Member
    24 SR5P
    sr5 is strictly a commuter car. Is it ok to use 4 wheel drive in the rain or is it putting an unnecessary strain on the drivetrain
  2. Nov 21, 2024 at 5:42 PM
    Part time 4wd (what you have) is generally not for rain use.
    thomason84 and icebear like this.
  3. Nov 21, 2024 at 5:42 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    The SR5 has the same drivetrain as the Off Road.
  4. Nov 21, 2024 at 5:45 PM
    teddy4x4
    24 SR5P
    So I should only switch to 4 wheel drive on the snow
  5. Nov 21, 2024 at 5:47 PM
    scanny
    scanny New Member
    Ontario, Canada
    I think it's ok if you don't do it often and don't make sharp turns.
  6. Nov 21, 2024 at 5:48 PM
    Snow is slippery enough to allow the drivetrain to unload.
    2Toys likes this.
  7. Nov 21, 2024 at 6:15 PM
    I take advantage of wet roads to exercise the 4WD.
    RUNNER4DAN likes this.
  8. Nov 21, 2024 at 6:27 PM
    Beachguy
    2024 TRP ORP
    While it doesn’t add any traction or advantage, putting it in 4H for a mile or so will hurt nothing. I have to do that with mine every so often because I don’t use
    This.
  9. Nov 21, 2024 at 7:07 PM
    Daddykool
    I have done so in very heavy downpours on freeway or highway. It does help reduce hydroplaning (along with reducing speed). And the downpours are typically brief. I disengage when the rain returns to normal.
  10. Nov 21, 2024 at 7:41 PM
    orcking
    orcking New Member
    It would not hurt...
    And it is good to put your truck in 4WD every while to keep it from seizing....
    do not over speed or make sharp turns...
  11. Nov 21, 2024 at 8:18 PM
  12. Nov 21, 2024 at 8:56 PM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    Manhattan likes this.
  13. Nov 21, 2024 at 9:02 PM
    Yamahamer
    Nevada
    Snow. Loose dirt/gravel. Anywhere you could easily spin the tires by just goosing it. Any surface like that where slippage of the tires can relieve the binding that would occur if you drove in 4wd on a high-traction surface like pavement.
    Manhattan and icebear like this.
  14. Nov 21, 2024 at 9:20 PM
    curious what you mean by over speed? After you switch to 4WD is there a speed limit to drive in 4H?
  15. Nov 21, 2024 at 11:25 PM
    icebear Recovered Kia Owner
    Technically there isn't, just maximum speeds for shifting in/out of 4WD in the manual.
    So you can send it to top speed once you're in 4WD in theory, but naturally whether that's prudent is something else.
  16. Nov 22, 2024 at 4:21 AM
    Daddykool
    In a RWD vehicle, while driving, friction from the road causes the front wheels to rotate. Hydroplaning at the front wheels occurs when there’s enough water to cause the front wheels to lose contact with the pavement. When this happens, the front wheels will slow a little, allowing a ‘buildup’ of water to occur. The ability to steer accurately is reduced. With 4WD engaged, the wheels are mechanically forced to rotate, rather than depending on friction from the pavement. This reduces the likelihood of hydroplaning a little.
    Beachguy and Patcell like this.
  17. Nov 22, 2024 at 4:55 AM
    orcking
    orcking New Member
    To switch to 4H you have to be under 50 MPH
    To switch to 2L you have to be in neutral. and only designed to be at very low speeds.
    Since both drive shafts are locked in 4H, It will be harder on the wheels on dry pavement. hence do not over speed or over corner.
    Both front and rear wheels still have their own differentials..., but both drive shafts front and rear is getting 50% torque.
  18. Nov 22, 2024 at 6:04 AM
    thomason84
    thomason84 New Member
    2022 supercharged and lifted 4Runner
    Bilstein 8112 lift Magnuson Supercharger YotaWerx Stryker+ tune Sherpa Crestone rack Lots of other small stuff
    Wet roads are still considered a high friction surface and unless you have bald or super hard compound tires that allow slip do NOT put it in 4WD on wet roads. AWD is good for wet roads because all 4 wheels provide directional traction so if you find yourself in very specific circumstances you have a slight advantage. However, 4WD works against you in rain and reduces your safety. Turning (even slightly) introduces binding in the drivetrain and if you have good tires this binding will damage your transfer case. If you have bad tires they will slip reducing your traction and can cause bad things to happen. Keep 4WD for off-road or snow/ice use only. If you need (or want) 4WD for rain get a Limited.
  19. Nov 22, 2024 at 6:11 AM
    Manhattan
    Manhattan New Member
    Not sure that's how it works. This: "...the front wheels will slow a little, allowing a ‘buildup’ of water..." Hydroplaning is the result of the tires' inability to move the water away faster than it encounters it. No one hydroplanes at 25mph. The better the tire design and condition (at channeling water), the heavier the vehicle relative to the contact patch, the closer to 50/50 weight distribution... These are the constants. The variables are the speed of the vehicle and volume of water. Assuming the same constants and variables - FWD, AWD, RWD will hydroplane equally.
    BUT, and it's a big but, AWD (almost wrote "will recover") offers the driver the ability to better recover when hydroplaning starts.
    Oh... yeah, don't use 4WD in the rain. Save it for unpaved surfaces.
    Daddykool[QUOTED] likes this.
  20. Nov 22, 2024 at 6:12 AM
    Interesting. Only know of 2 different speed limits between rotating selector vs manual selector to shift in. I believe shifting out does not have a speed limit.
    I have to search to see if there is anything bad driving at high speed in 4H.
    whippersnapper02 likes this.
  21. Nov 22, 2024 at 6:39 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    So you're saying it could hurt...
    If you're on a proper surface to use 4H, speed isn't going to hurt the drivetrain...if it might hurt the drivetrain then you're not on a proper surface for 4wd...
    meh, prudent depends on tires and driver ability, just like driving on a dry, sunny day...
  22. Nov 22, 2024 at 6:41 AM
    Daddykool
    Right. Still, I've briefly engaged 4WD under sudden, severe changes in rainfall, when I was unintentionally going too fast for this sudden cloudburst. It did help in those situations. I do not advocate driving like that for an extended period.
  23. Nov 22, 2024 at 7:07 AM
    Whoops, I don’t remember if I’ve ever seen a limit on shifting-out-speed so that’s probably an error on my part.
    kmeeg[QUOTED] likes this.
  24. Nov 22, 2024 at 7:30 AM
    Yeah no limit once in. My buddy recorded us messing around on a dry lakebed. I’m in the supercharged Taco going all the way up to the governor. 4wd is only going to give you forward traction but do nothing once you’re up to speed. It can possibly help you with engine braking on a really slippery surface.
    https://youtu.be/ZHwwWX9y1uA?si=Y1I7j9meXP5naeDR
    kmeeg likes this.
  25. Nov 22, 2024 at 7:38 AM
    That looks like a fun day...!!!!!
  26. Nov 22, 2024 at 7:47 AM
    Definitely good times when I used to go out. I don’t take the Runner out at all now. The Taco recording is an absolute monster now.
  27. Nov 22, 2024 at 7:51 AM
    I watched that small clip from your friends youtube. That a fun truck to drive.
