3vze swap to 5vz help
Discussion in '2nd Gen 4Runners (1990-1995)' started by Joshtemple, Feb 3, 2020.
  1. Feb 3, 2020 at 2:31 PM
    Joshtemple
    Joshtemple [OP] New Member
    Josh
    91 4Runner
    I have a 1991 Toyota 4Runner With a 3.0 and I’m wanting to swap it to the 3.4 I have the motor and the conversion components I’m just looking for a good local shop who has done it before that I can take my run or two and have them do the swap for me I am located in Southern California in the inland Empire
  2. Feb 3, 2020 at 2:46 PM
    dcsleeper408 likes this.
  3. Feb 3, 2020 at 6:20 PM
    Joshtemple
    Josh
    91 4Runner
    Thank you for the response I gave the guy a call he more or less told me it’ll be about $6000 Which is 2000 more than what I had to put into it but thank you anyways
    SlvrSlug likes this.
  4. Feb 12, 2020 at 9:23 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Josh, the $6K sounds to me like a no bid price. You may have to do this yourself or go with one of the companies that offers this as a service.
  5. Mar 17, 2020 at 10:46 AM
    Marlin Crawler T-Revv
    Marlin Crawler T-Revv Lead Sales Marlin Crawler
    Trevor
    1992 4Runner Crawler
    SAS, 5.29 gears, Tacoma Elockers front and rear, Marlin Crawler Dual Ultimate transfer cases, All- Pro leaf springs, 37" tires, chromoly axle shafts, Marlin Crawler R150F Transmission, Marlin Crawler front and rear bumpers, Marlin Crawler Sliders, Marlin Crawler Axle armor.
    Call Mike @ offroad Solutions. He's in colorado, so that would be a long drive for you, but if you get a quote from him than you know about what the cost for the job is to compare.
