3 inch lift, 285s, -12 offset wheels
Discussion in '5th Gen 4Runners (2010-2024)' started by TacoJuan, Feb 10, 2020.
  1. Feb 10, 2020 at 7:13 PM
    TacoJuan
    TacoJuan [OP] New Member
    2016 Black Trd Off-road
    I’m sure the info is out there, but I’ve been searching and can’t find exactly what I’m looking for. I’m looking for anyone running a 3 inch lift with 285/70r 17 tires and 17x9 wheels with -12 offset and aftermarket UCAs. I’m on the fence of weather I should get a 2.5 inch lift and 275 tires or 3 inch and 285s. I’m trying not to do any cutting, pushing the fender liners forward at most. So if anyone can chime in, I’d appreciate it. Tia
  2. Feb 10, 2020 at 8:59 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I have most of those things.
    2.25" lift.
    Stock UCAs
    285/70/17 K02s
    17x9 w/ -12mm offset
    Rubbed, not too bad, but required a little work and mudflap removal.
    The lift won't help with the rubbing, the -12mm offset and 285mm tire width will rub. If you lift higher, it just won't rub until you uptravel on a big bump while turning the wheel is hit harder.
    Lifts won't prevent rub, they mask it. If you never cycle the suspension enough to find where it rubs you'll be fine. But eventually with that setup, you'll rub.
    nimby, TacoJuan[OP] and SlvrSlug like this.
  3. Feb 10, 2020 at 9:18 PM
    TacoJuan
    Thank you for your reply! What was the little bit of work you had to do? Was the cmc necessary?
  4. Feb 11, 2020 at 8:00 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Just a little trimming on the front bumper and heating up pushing in the plastic. Like 2" of trim on the bottom, you can't see it unless you go hunting. Also, remove front mud flaps. That was pretty much it. Backs are fine.
    TacoJuan[OP] likes this.
  5. Feb 11, 2020 at 8:29 PM
    tonycaputo
    tonycaputo New Member
    Tony
    Vancouver
    2019 Black 4Runner Off-Road
    2.5" lift, light racing UCA, 285/70/17 KO2s, 17x9 wheels with same offset. I removed the mudflaps, no rubbing on the cab mount, and no trimming required. Only clips the front bumper plastic when in full lock reverse turning right.
  6. Feb 12, 2020 at 12:54 AM
    TacoJuan
    That’s not too bad, I think I’m going to go ahead with the 285s
  7. Feb 12, 2020 at 12:56 AM
    TacoJuan
    Thank you! That’s pretty minimal!
  8. Feb 12, 2020 at 8:27 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    I'll try to make a video of it later tonight if I get a chance to upload so you can see. If you're not scared to saw on the truck you'll be fine :)
  9. Feb 12, 2020 at 9:00 AM
    TacoJuan
    That would be awesome! Yea I’m not worried about it within reason lol.
  10. Feb 13, 2020 at 5:13 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
  11. Feb 13, 2020 at 9:11 PM
    TacoJuan
    That’s awesome! Thank you for making that! I’m going ahead with the 285s now. That was a lot of help!
    fajitas21[QUOTED] likes this.
  12. Feb 14, 2020 at 10:00 PM
    jonny_04
    jonny_04 New Member
    '19 TRD Off Road w/KDSS
    King Shocks 2.5 w/adjusters, Total Chaos uca, Icon 2" rear coil, Nitto Ridge Grapplers 285/70/17, Rigid D-Series amber fog lights, Morimoto HID & LED lights, Meso custom dome light.
    i agree with Tonycaputo; i just removed my front mud flaps and did minimal trimming on the bumper cause it does rub when reversing at full lock.
  13. Feb 24, 2020 at 11:55 AM
    Khens12
    Khens12 New Member
    19’ T4R Off Road
    Installed: 20% Ceramic Tint / Pro Grille and LED’s On Order: 2.5 King Coilovers / 2.5 (2) tube bypass shock / Icon UCA / 17” Icon Compression wheels / Eibach 1” lift rear springs / SDHQ Light Bar Mounts / SDHQ Ditch brackets
    I know you are running a different tire size but I’m trying to figure out how much trimming I’ll have to do with the -12 on a 265 or 275/70r17 on stock suspension. This is temporary until we get suspension and lift it a tad.
  14. Feb 24, 2020 at 3:51 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    You likely will need to remove mudflaps (maybe not, but likely yes), and you'll have some on the bottom. You'll certainly have to push in the fender liner some, but that's pretty easy with a heat gun. The real test is cycle the suspension out completely and note where it touches. I'd recommend full stuff while the wheel is all the way left and then right, then do that for the other front wheels. The rears will require nothing.
