3/8" Drive for Differential Plugs
Discussion in '5th Gen 4Runners (2010-2024)' started by marinrunner, May 4, 2022.
  1. May 4, 2022 at 6:11 AM
    marinrunner
    marinrunner [OP] Not a New Member
    2023 ORP, MGM
    Stock on Mickey Thompson Baja Boss, XL load, 265/70/17
    Is it okay to use 3/8" drive (breaker, torque) for rear diff plugs?
    I know correct socket size is 24mm (6 point) @ 36 ft lb.
    The few posts that mention drive size usually says they're using 1/2" drive.
    Is that just because most don't have a 26mm in 3/8" drive?
    Seems like a 3/8" torque wrench would be more accurate than 1/2" in this low torque range.
    Just want to make sure that 3/8" is going to be robust enough to remove and replace fasteners without any issues. Will use PB blaster and have breaker bar. Not planning on using any adapters. Will get true 24mm 3/8" socket. Open to getting 1/2" setup if that's the right thing to do.
    What do you think?
  2. May 4, 2022 at 6:39 AM
    afret
    North Idaho
    I've used 1/2" to 3/8" adapters to torque Ford truck wheel lug nuts to 165 ft-lbs.
    marinrunner[OP] likes this.
  3. May 4, 2022 at 10:19 AM
    MAXIM
    MAXIM New Member
    It'll be fine.
