3.0 PCV valve replacement
Discussion in '2nd Gen 4Runners (1990-1995)' started by D60, Jan 14, 2021.
  1. Jan 14, 2021 at 10:39 PM
    D60
    D60 [OP] New Member
    I did this on a '93 today. First, yeah there's already a TON of info out there on this but it seems to either be "it's a huge hassle" or "just pull the upper intake."
    This was an amusing thread, if a bit dramatic:
    https://www.yotatech.com/forums/f120/pcv-valve-change-3vze-3-0-v6-218389/
    I didn't find it that bad. The three keys are:
    1) get the vehicle elevated to where you can see under the upper intake when standing at the pass side fender. I used my lift but honestly a floor jack might be even better 'cause it'll "tip" the vehicle to the driver side
    2) remove everything that obstructs your view. The EGR actually doesn't have to be touched
    3)have the right tools. I used some GW hose pliers to pull the PCV hose and some 45* extended needle nose to yank the valve. The "Double X" design of the latest extended pliers has merit because you don't have to physically spread the handles that much to get a lot of opening at the work end.
    I had the old valve removed in 15 min taking my time. It actually took me longer to put everything back together as I referenced pics on my phone trying to figure out where all the lines were.
    PHOTO 1: what you're facing before removing obstructions = zero visibility
    PHOTO 2: what you can see once offending hoses are removed and vehicle is at a good height for you. Valve already removed in this photo but grommet visible in valve cover
    PHOTO 3: the height I selected being roughly 5'10"
    PHOTO 4": helpful tools
    bthp223 likes this.
  2. Jan 15, 2021 at 10:17 AM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Nice documentation of the method D60.
    Typical 3VZ-E with 9 hoses and the cold start injector line needing a yank.
    It is darn shame that ruddy fuel pressure dampener can't be gotten at like this! My son Bradly's 1990 4Runner has a failed one and were pulling the plenum when the new one arrives.
    Cheers
  3. Jan 16, 2021 at 9:31 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    It's a damn shame they put that on the right cover and not the left. Would have made changing it much simpler.
  4. May 22, 2021 at 7:06 PM
    Pyroslinger
    Pyroslinger 1995 Hi-Lux Surf 3.0 3VZE Factory 250,000
    Pyroslinger
    Montana
    1995 Hi-Lux Surf SR-5 3.0 3VZE / Bought at 29,000 - Present 250,000/ Rusted Body, Excellent Otherwise
    Factory/ 2" Ol Man Emu Rear Springs/ Skyjacker Shocks/ Cat- Back Exaust/ K&N Air Filter/ Denso Iridium Plugs/Neoprene Vacume Lines/Sony CD Head Unit+Focal Factory Fit Speakers
    Very well done!! Hell...I may even give mine a go! Thanks!
  5. May 22, 2021 at 7:59 PM
    mostlystock93
    mostlystock93 New Member
    93 4runner 3vze 4WD, Ellsworth Enlightenment 29er
    slight lift, aftermarket headers, cold air intake
    Uggh-this can be a pain of a job if it’s the original. The old grommet gets dried out and breaks and the pieces will get stuck in the camshaft coverplate metal divider piece (only seen if you pull the cover). The new one will go in easily though
  6. May 24, 2021 at 2:01 AM
    Pyroslinger
    Pyroslinger
    Montana
    Gotta get it done!:facepalm:
