2nd row seat re-install issue
Discussion in '5th Gen 4Runners (2010-2024)' started by IDK, Jan 25, 2025.
  1. Jan 25, 2025 at 10:57 AM
    IDK
    IDK [OP] New Member
    Hello
    What's the secret to getting the passenger side 2nd row seat re-installed? I've tried putting on the bracket on the pass. side, leaving it loose, but the holes on drivers side are off (see pic). I also tried the opposite way, but the bracket won't fit around the plastic trim.
    Thanks for any help.
  2. Jan 25, 2025 at 1:01 PM
    welcome
    IDK[OP] likes this.
  3. Jan 25, 2025 at 1:23 PM
    Photon_Chaser 51,023 and counting…
    Sierra Nevada Mountains and the Central Coast
    Maybe try loosening up some of the bolts that attach that bracket to the seat base will allow for some wiggle room? At least you can get the floor fastener started/torqued down then re-tighten the ones used to attach the bracket to the seat base.
    IDK[OP] likes this.
  4. Jan 25, 2025 at 1:44 PM
    Oakboro, N.C
    All of the above plus repositioning the seat if it is in the stored position and retry to see if that changes the bracket angle/orientation.
    IDK[OP] likes this.
  5. Jan 25, 2025 at 1:48 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    BFH!…
  6. Jan 26, 2025 at 3:10 AM
    Welcome. And yes on the putting everything in half way then tightening. You need that play.
  7. Feb 3, 2025 at 3:53 PM
    IDK
    IDK [OP] New Member
    I got it. It was an IDIOT (me) mistake. For anyone reading this, be sure you use the correct bracket (left or right) or it won't fit. THANKS GUYS FOR YOUR HELP.
