24 4Runner - Oil pressure issue, TAS investigation ongoing.
Discussion in '5th Gen 4Runners (2010-2024)' started by trevor1030, Aug 29, 2024.
  1. Aug 29, 2024 at 2:20 AM
    trevor1030
    trevor1030 [OP] New Member
    Trevor
    24 4Runner TRD Pro, 23 Tacoma TRD Pro
    Hi all i have a 2024 4runner Turd pro, i recently installed a TRD intake over the weekend and it was all dandy until a day ago i had random oil pressure low flicker a few times only at stop light/idle. It usually goes away after 3-4 seconds then maybe 4-5 seconds it will pop up again. So needless to say i took it into the dealer, they have not been able to fix it and i am told it will be looked at by a toyota engineer. Im quite salty as it only has 3400 miles on it. I think its the sensor, or maybe i nicked a wire when cutting the tape for the trd intake install. Im not sure, but i hope it is fixed as i had some big plans for a build.
    my last thing i wanted to mention i noticed, is that i work nights and noticed that my raptor lights sometimes are randomly on when i get back from work. I wonder if this is something else in the electrical affecting the oil pressure light etc. I will probably uninstall the raptor lights as the shop installed the fuse into the engine bay fuse box 10A INJ as i saw that its recommended to install in the cabin fuse box. I like how it looks but if its gonna randomly turn on ill remove them. If anyone has any experience with anything like this or any input/ideas on what it could be i would appreciate it. I will keep the thread updated with updates from toyo.
    Thanks
    Trevor
  2. Aug 29, 2024 at 3:30 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Wait, your mad at Toyota because you might have cut a wire? Or it might be something due to your after market lights?
    I hope you figure it out so your Turd can be a TRD again.
    Mully410, 2Toys, catbrown357 and 4 others like this.
  3. Aug 29, 2024 at 4:47 AM
    VAkdubsHI
    VAkdubsHI New Member
    24 Limited, 2013 Taco OR
    Can’t speak for the intake/ sensor situation but I can say that the raptor lights being temporarily/ randomly on is likely because of where you tapped into/ whichever fuse you used. The drls for the morimoto xb in the 2nd gen Tacoma can do this bc the power source they have you tap into gets power/ “turned on” when the vehicle runs behind the scene diagnostics when it’s off. Likely the same thing is happening for your situation.
    2ndGen22re likes this.
  4. Aug 29, 2024 at 5:16 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Be prepared to pay for the fix if it's caused by something you modified.
    2Toys, catbrown357 and 2ndGen22re like this.
  5. Aug 29, 2024 at 5:38 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Aftermarket electrical mods. Every. Single. Time. If you search through the forum you will find dozens if not hundreds of posts about people having issues when messing with the electronics. For whatever reason, the 4Runners do not play well when you tap into the electrical system.
    I'd say there is a high probability it's your raptor lights. Uninstall them and test it for a while, bet your light issue goes away. If not, second suspect is the intake and anything that was messed with during installation.
    Good luck!
    MeefZah, Rocko9999 and 2ndGen22re like this.
  6. Aug 29, 2024 at 5:45 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Electrically and mechanically mine will be untouched until the warranty is up. Dealers look for every excuse possible to shrug off responsibility. Double that for motorcycle dealers.
    kouack likes this.
  7. Aug 29, 2024 at 5:47 AM
    garoto
    garoto New Member
    For the TRD Intake installation I used an extension cable for the MAF, requiring zero cutting or splicing of the factory wiring tape or conduit.
  8. Aug 29, 2024 at 5:48 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    lol raptor lights. It’s like a hooker. Nothing good can stem from raptor lights on a 4r. Stay away
    CalcityRenegade, MeefZah, TSM and 2 others like this.
  9. Aug 29, 2024 at 6:19 AM
    There’s an extension harness from Michigan Motorsports for the MAF so you didn’t have to cut for the TRD intake that does nothing.
    The truck does an EVAP test after a few hours after running, which is mentioned in the manual, so the circuit you used for the craptor lights is active during that test.
    If it is indeed a real oil pressure problem, the odds simply were not in your favor.
    catbrown357 and 3JOH22A like this.
  10. Aug 29, 2024 at 6:51 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    So far, everyone assumed that loss of oil pressure is not occurring and this is false warning due to electrical issues. This is reasonable assumption on a new 4Runner.
    However, if low oil pressure is actually happening it is resulting in engine damage every time it happens. I strongly recommend investigating oil pressure AND performing oil analysis. It is possible that OP is extremely unlucky and got a defective oil pump. In such case, simply replacing the oil pump is not adequate - at the minimum new crank bearings have to be put in.
    1SilverRunner likes this.
  11. Aug 29, 2024 at 7:36 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    Not wrong, but why now? Is eliminate all the possibility of user error first, the more untouched the vehicle looks/is the more likely yota will check the oil system.
  12. Sep 1, 2024 at 1:11 AM
    trevor1030
    Trevor
    what fuse is recommended for the raptor lights and morimotos? I ordered a set and did some research on the fuse it was plugged into 10A INJ. From what I’ve read this is correct? I’m not sure what to plug the DRL in for the morimotos.
  13. Sep 1, 2024 at 1:17 AM
    VAkdubsHI
    Honestly don’t remember (super helpful, I know). I opted to leave the DRL unplugged bc (1) I didn’t like the fact that they would be on all the time/ seems like it would lead to unnecessary use and (2) don’t think there was a work around to it unless you also add a rocker switch for them (I looked at the electrical diagram and then said fuck it).
    here’s the install instructions for them - again, it’s a Tacoma, but likely in the ballpark https://5129608.app.netsuite.com/co...TxsLNQNFGhpwtyQ0Ps2m0IZxqcTB02x8c_uu&_xt=.pdf
  14. Sep 1, 2024 at 9:39 PM
    Steve Berman
    Steve Berman New Member
    i put nitrous on a rental kia sophia
    Kad2112 likes this.
  15. Sep 5, 2024 at 4:02 AM
    trevor1030
    Trevor
    Still at dealer Toyota claims to have never seen this issue before so running a lot of diagnostics. From what I gathered they are going to be installing new wiring. They checked the oil pressure and everything is fine. Swapped the sensor still same issue.
    Spare Parts likes this.
  16. Sep 5, 2024 at 4:47 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    Raptor lights go in the grille though
    not the trunk
    RUNNER4DAN likes this.
  17. Sep 5, 2024 at 7:18 AM
    Yobruhitsme
    Denver
    Was in the drive thru the other day.. a 4r was behind me.. the dude had raptor lights.. sure enough the pos was flashing/ blinking like the wires were shorting out lol
    even if it wasn’t blinking, the look was still trashy af. Broad daylight.. a row of orange lights lit… lol
    Nick B likes this.
  18. Sep 17, 2024 at 3:58 PM
    trevor1030
    Trevor
    update: got word from my dealership that a Toyota engineer came to look at the engine. I am told that they have to replace the oil pump and timing cover. They confirmed that is 100% the issue and its a very rare issue that they have only seen affect a 2-3 in the past. Fingers crossed its fixed when i get it back.
    Jere39, McSpazatron, BS67 and 2 others like this.
