22 Frame Repair
Discussion in '5th Gen 4Runners (2010-2024)' started by Silentshredr, Sep 5, 2023.
  1. Sep 5, 2023 at 3:00 PM
    Silentshredr
    Silentshredr [OP] New Member
    22 Trd Off Road
    Jumped over here from TacomaWorld looking for more information. To make it short our 2022 was hit in the side directing force onto the rear axle. Good chance the frame is tweaked by the looks of it. Can these be straightened or do they need to be replaced. Checking before repair move forward, thanks in advance.
  2. Sep 5, 2023 at 3:04 PM
    I'd replace any frame if you ask me.
    But it wasn't totaled?
  3. Sep 5, 2023 at 3:10 PM
    Silentshredr
    22 Trd Off Road
    Doesn’t look damaged other than rear axle slightly tweaked. Will see this week. I didn’t know if shop will fix or replace and what to not let them do
  4. Sep 5, 2023 at 3:11 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    So what does the adjuster say?
    Captain Spalding likes this.
  5. Sep 5, 2023 at 3:18 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Probably not a write off due to the value.
  6. Sep 5, 2023 at 3:24 PM
    Silentshredr
    22 Trd Off Road
    I agree, just didn’t know whether it was a reframe or pull it back into spec.
  7. Sep 5, 2023 at 4:06 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    frame is pretty sturdy and hopefully just the trailing arms were tweaked.
    id be ok with a frame pull in the rear if it’s needed. way easier to get a solid axle to mount straight over the independent front suspension.
  8. Sep 5, 2023 at 4:06 PM
    Maybe there’s a chance only the links are tweaked, and the frame itself is not damaged. That would be a fairly straight forward “bolt on” repair I would guess.
    But if you have it insured, makes sense to go through them.
  9. Sep 5, 2023 at 4:12 PM
    This is the key question. If the adjuster says insurance will pay to have the frame straightened are you going to pay the difference out of pocket for a new frame?
    My experience is that as the size of any repair job grows, the odds of it being done right shrink. In my opinion, and owing to your use of the word “tweaked”, I would be more confident in a successful repair if the frame were straightened.
  10. Sep 5, 2023 at 4:20 PM
    Which is why I was asking.
  11. Sep 5, 2023 at 4:20 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Straightening a ladder frame isn't a big deal
    Toy4X4 and Captain Spalding like this.
  12. Sep 5, 2023 at 5:47 PM
    3JOH22A Toyota Gigolo
    Not likely given the crossmembers are right there. Links may be bent and the panhard mount may be bent/broken, but those are replaceable.
  13. Sep 5, 2023 at 5:55 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Remember that the insurance company will still be your insurer after the claim. That means that they have an incentive to make sure the repair occurs in a manner that keeps the vehicle safe and roadworthy.
    Meanwhile, most body shops will ask how you’d like things to go. While the adjuster can overrule some of the body shop’s judgement calls, there is always going to be a certain amount of gray area.
    Toy4X4, McSpazatron and Thatbassguy like this.
  14. Sep 5, 2023 at 6:27 PM
    There’s a lot of gray area between straightening the frame and replacing it.
    Slopemaster and Silentshredr[OP] like this.
  15. Sep 5, 2023 at 6:38 PM
    Silentshredr
    22 Trd Off Road
    Agree, Hoping the links are bent but the steering wheel is off also. Not sure if this could be from shock of everything or the one side of the frame rail shifting back.
  16. Sep 5, 2023 at 9:03 PM
    The steering might appear off center if the rear axle isn’t tracking straight ahead…could be crabbing.
    Wait, do you have a tacoma, or a 4runner?
    JETSPD1477 likes this.
  17. Sep 6, 2023 at 2:41 AM
    Silentshredr
    22 Trd Off Road
    Both, this happened to the 4runner
  18. Sep 6, 2023 at 7:29 AM
    steelevo
    Utah
    Has the body shop checked the frame alignment to determine if it’s in spec or not?
  19. Sep 6, 2023 at 9:21 AM
    Silentshredr
    22 Trd Off Road
    Not yet, will keep all updated. Appreciate all the input
  20. Sep 6, 2023 at 11:01 AM
    LCA cam bolts probably shifted (like it happens most of time off road).
  21. Sep 6, 2023 at 11:29 AM
    2X4Runners
    2X4Runners New Member
    Sorry for your troubles. A frame or structural repair on the Carfax will cost you a minimum of 10%-15% of the vehicle value at trade in time. A lot dealers won’t take a vehicle with that history on trade at all, Carvana/Vroom won’t buy it for resale. and the value for a potential private buyer will be much lower as well. IMO, if you’re going to move ahead with the repair, now is the time to agree to the diminished value claim with your insurer so that you can recover some of that money at least. Good luck!
    Technologic80 and K-Paul like this.
  22. Oct 28, 2023 at 9:04 AM
    Silentshredr
    22 Trd Off Road
    Out of the shop! It was apparent it was the rear end assembly that was bent once it was removed and laying on the ground. The frame measured within spec and seems to be unscathed. Complete rear assembly along with all links were replaced. I believe we had the best case scenario. Thanks for all the prior input.
    2X4Runners and Too Stroked like this.
  23. Oct 28, 2023 at 9:18 AM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Former body shop appraiser and Insurance adjuster here. THIS IS THE WAY....
    Technologic80 likes this.
  24. Oct 29, 2023 at 9:34 AM
    Bivouac09
    Bivouac09 New Member
    Bivouac
    2012 4Runner.
    Unknown
    A hard call to make without being up close and in Person .
    If the Truck still has a Loan the loan holder might insist on the frame being replaced to keep the market value as high as possible.
  25. Oct 29, 2023 at 3:57 PM
    08TXRunner
    '20 SR5P
    That post was nearly 2 months ago and the OP already updated the thread.
  26. Oct 29, 2023 at 6:10 PM
    Bivouac09
    Bivouac
    2012 4Runner.
    Unknown
    Dates I tend to miss all to often.
