22-23 TPWS Tire Pressure Sensor Source
Discussion in '5th Gen 4Runners (2010-2024)' started by racinjason, Aug 21, 2023.
  1. Aug 21, 2023 at 6:23 AM
    racinjason
    racinjason [OP] New Member
    I was researching adding an additional wheel set to my 23 ORP. I landed on a couple of threads linked below that assisted with my search. I eventually found that the Denso 550-0118 is the exact part installed in my original wheels. There were no pictures of this particular Denso sensor that I could locate, so I ordered a set from Rock Auto at $34.79 each. The sensor from Toyota OEM suppliers is around $70 each.
    I can confirm that adding these through the "Change Wheel Set" function detailed in the owners manual worked flawlessly, and I was able to read the new sensor pressure, and turn off the light on the dash in 2 miles of driving.
    Hopefully this helps others that would like to add additional sensors to their 4Runners.
    Threads that assisted:
    https://www.4runners.com/threads/tpms-sensor-installation-procedure-help-needed.31401/
    https://www.4runners.com/threads/tpms-sensors-for-2022-trd-orp.25759/
  2. Aug 21, 2023 at 7:45 AM
    steelevo
    Utah
    Welcome and a great new member post! Thank you for contributing to the forum.
