21 4runner transmission fluid change
Discussion in '5th Gen 4Runners (2010-2024)' started by TRD5thgenner, Dec 13, 2024.
  1. Dec 13, 2024 at 5:05 PM
    TRD5thgenner
    TRD5thgenner [OP] Not Very Well Known Member
    2021 4runner TRD Offroad Premium
    My 21 4runner has 62k miles and I want to get the fluid changed on the transmission. I was thinking of just doing it myself but my 4runner is under warranty until 100k miles so I was just thinking of having the dealer do the service. They quoted me at $400. Is it worth just having the dealer do it? Or should i go to a reputable shop and probably save some $$?
  2. Dec 13, 2024 at 5:06 PM
    I don’t remember what I paid to have the dealer do my Tacoma but it wasn’t $400. Shop around at other dealers and make sure they are doing full exchanges for that much money.
    TRD5thgenner[OP] likes this.
  3. Dec 13, 2024 at 5:17 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    Agreee on finding a different dealer. My Toyota dealer charges $250. I’m at 58k on my 21 Venture.
    They’re also recommending a radiator flush at 60k - also at $250.
  4. Dec 13, 2024 at 5:18 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Do it yourself for about 70 bucks. Just buy 4 qts. of Toyota WS and do a drain and fill. Bunch of YouTube videos to guide you. Wouldn't worry about it affecting your warranty.
    Scarif_1, Curt56, Rocko9999 and 2 others like this.
  5. Dec 13, 2024 at 5:18 PM
    TRD5thgenner
    I think they said drain and fill
    Sleestaks likes this.
  6. Dec 13, 2024 at 5:20 PM
    TRD5thgenner
    Hmm might look into this
    Startrek likes this.
  7. Dec 13, 2024 at 5:21 PM
    I just did two drain & fills about a week apart with WS fluid and a $25 brass hand pump. Used a no-name bluetooth OBD2 reader to read transmission pan temp and opened the check plug at the correct temperature range.
  8. Dec 13, 2024 at 5:25 PM
    TRD5thgenner
    Can you link the reader?
  9. Dec 13, 2024 at 5:32 PM
  10. Dec 13, 2024 at 5:33 PM
    Way too much then.
  11. Dec 13, 2024 at 5:34 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Slopemaster likes this.
  12. Dec 14, 2024 at 12:26 AM
    icebear Recovered Kia Owner
    I got a ScanGauge because my cheap $30 Bluetooth OBD scanner died after a year or two.
    https://www.carscanner.info/choosing-obdii-adapter/
    If you don’t mind sliding underneath, you should DIY it and coolant is even easier IMO. (if a little more tedious waiting to get air bubbles out)
    For warranty purposes you typically just need documentation/receipts. If you don’t want to do it, get quotes from other independent shops.
    BUT, there is no 100k warranty via Toyota. Check the fine print, if it’s a dealer perk it likely requires every single thing be done by them, at their prices which makes it a baaaaad deal, even worse on a 4Runner as well as easy to find a reason to deny. (Oops you traveled! Go kick rocks! - some do have an exception though but it varies)
    If it’s a third-party, with proper documentation, you got a good shot but fine print trumps all.
  13. Dec 14, 2024 at 10:52 AM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    I guess my other question is does the radiator need flushed at 60k or is 100K more like it? Just curious of the thoughts here. For us the miles are mostly rolling down the interstate at 70mph on cruise control. Not crawling along in hot city stop and go traffic.
  14. Dec 14, 2024 at 11:00 AM
    100k for coolant.......at least for the first time.
    I saw someone say every 50k after the first one but double check that.
    Mully410 and Ripper238 like this.
  15. Dec 14, 2024 at 11:06 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Did my trans fluid at 60k at dealer, now i have a independent master mechanic that's going to do it again at 100k and he also suggested 100k for coolant. Ill check if 50k after, but 100k should be fine for coolant.
    nimby[QUOTED] likes this.
  16. Dec 14, 2024 at 12:25 PM
    I started doing my coolant (radiator only) drain/fill early - my thinking is since it only replaces somewhere around half of the fluid (and I don’t want to mess with draining the block or a flush) I’ll do it every 3ish years, 30-45k miles to keep things at least kinda fresh but I wouldn’t fault anyone for deciding to go longer.
  17. Dec 14, 2024 at 1:26 PM
    The block drain is pretty easy to get to. I was a little leery of doing it at first but afterwards realized it's no big deal.
    orcking likes this.
  18. Dec 14, 2024 at 2:26 PM
    Guppy1301
    Silver 2019 TRD ORP
    Good to know. I'm changing my coolant, radiator hoses, and cap this winter.
  19. Dec 14, 2024 at 3:18 PM
    Just make sure the tubing you get for the drain spouts of the radiator and block fit tightly. Test fit both. A tight fit helps tremendously with making the job cleaner.
    Guppy1301[QUOTED] and icebear like this.
  20. Dec 14, 2024 at 5:36 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    Do a search for the pressure sprayer method. 30 minutes, does a complete fluid change for the cost of the fluid and a pump up pressure sprayer. Done it 3 times on different trucks.
  21. Dec 15, 2024 at 9:09 PM
    orcking
    orcking New Member
    Just did my rad flush at little less than 60K
    very easy.. two gallons of 50/50 Toyota antifreeze and the whole thing takes like an hour...
    This guy has great DIY videos..
    https://www.youtube.com/watch?v=ZkqGjj3L05Q
    Protect your cooling system and your water pump.
    two notes on the job:
    1- the tube was a little bigger and it leaked a bit. try to get a tighter tubing for the block...
    2- buy a new OEM rad cap ($16) and change your old one. The rad cap is a maintenance item and they do go bad occasionally, which could affect your cooling operation...
    TxTRD, nimby and Guppy1301 like this.
  22. Dec 16, 2024 at 5:21 PM
    Sleestaks
    Sleestaks Shape-shifting Reptilian Alien
    2018 OR, Magnetic Gray
    Tires only
    I use OBDLink MX+
  23. Dec 17, 2024 at 7:28 AM
    orcking
    orcking New Member
  24. Dec 17, 2024 at 9:06 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Which pump? The one I have sucks and leaks.
  25. Dec 17, 2024 at 10:08 AM
    Rocko9999[QUOTED] likes this.
  26. Dec 17, 2024 at 12:01 PM
    Rocko9999
    2011 Limited
  27. Dec 17, 2024 at 1:53 PM
    ^No. It has a suction hose that you submerge in the bottle. I keep the bottle in a slightly larger plastic tub to prevent the hose drag from tipping the bottle over (which would be a spill of some expensive fluid).
  28. Dec 24, 2024 at 11:35 AM
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    Not as complicated as you might think. DIY. And have peace of mind it was done correctly. Drain and filled w/out removing the pan at 60k. Probably do another at the 100k milestone.
  29. Dec 24, 2024 at 11:49 AM
    Photon_Chaser 48576 and counting…
    Roger
    Sierra Nevada Mountains
    I had my local dealership perform all this:
    • Drain and fill Transmission, add conditioner
    • Front and Rear Diff fluid change
    • Transfer Case fluid change
    • All applicable gaskets replaced
    • LS11 Limited Slip Axle Additive
    • Parts wash
    • AT 6600 Kit
    • Ultraguard 75W90 Full Synthetic
    Total cost was $401.50
    Was it worth it? For me the personal time savings made this a no-brainer...
    Ripper238 and 94hokie like this.
  30. Dec 24, 2024 at 1:38 PM
    All of these fluids for that price and labor? Yes, definitely worth it. Where is this?
