20x12
Discussion in '5th Gen 4Runners (2010-2024)' started by fokai671, Sep 23, 2024.
  1. Sep 23, 2024 at 7:43 PM
    fokai671
    fokai671 [OP] New Member
    al
    2017 black 4runner
    3inch lift
    hey everyone, i got a 2017 runner with a 3inch lift. I wanted to run 20x12 -44 wheels with 33s. does anyone know how much i’ll need to trim and if it’ll clear body mounts?
  2. Sep 23, 2024 at 8:00 PM
    I've never heard of that wheel size...got a pic of said wheel? It's hard to imagine what tire works on a 12" wide wheel...
  3. Sep 23, 2024 at 8:48 PM
    IMHO, this sounds like more trouble than it’s worth.
    Rocko9999 likes this.
  4. Sep 23, 2024 at 8:52 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    The negative offset (along with the width) will require a lot of work. Your scrub radius will be off too.
  5. Sep 23, 2024 at 9:11 PM
    Lost Woods
    Lost Woods New Member
    2024 SR5P
    Fuck the mount... you'll be rubbing the body with that. A stock TRDOR wheel with 33s will rub the mount. You're adding probably 5 inches to the outside of that tire so you're not even going to make it to the mount, you're taking out the fender.
  6. Sep 24, 2024 at 4:05 PM
    3JOH22A Toyota Gigolo
    You'll probably need to trim 3" from the fenders and tub the firewall.
    You in Hawaii or something? 20x12 -44 wheels would look ghetto anywhere else.
    Folks in Hawaii running those types of wheels typically do a 6" or higher drop bracket lift to avoid fender cutting. But it requires cutting a crossmember from the frame.
