2 Weeks old and I got my first scratch!
Discussion in '5th Gen 4Runners (2010-2024)' started by NeverTooLate71, Jul 2, 2024.
  1. Jul 2, 2024 at 8:43 PM
    NeverTooLate71
    NeverTooLate71 [OP] New Member
    Bob
    2024 4Runner SR5
    Damn, only 2 weeks old and I got my first scratch! One of my club member buddies was loading popup shade tents from my side yard into his truck in the driveway when he scratched my 2 week old Ice Cap 4Runner! Just a slight scratch, but a scratch all the same! I'm looking on Amazon but don't see what looks to be authentic Toyota touch up paint. I'll give the local Toyota Dealership a call tomorrow. I used to be a auto detailer when I was a college student so I can fill in the scratch fairly well. Hopefully I will have a steady hand. (Age 71)
  2. Jul 2, 2024 at 8:48 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    That sucks, sorry to hear. I got my touch up paint on Amazon but for super white (040). Not sure what the code is for ice cap but if it's new they may not have it yet and like you said, dealer will be best bet
  3. Jul 2, 2024 at 8:56 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @NeverTooLate71 aw man that must have been difficult to witness, painful on the inside!
    Goodluck
    ..alternatively, you leave the scratch all alone, and wear it haha (I’ve never bought touch up)
    JChiz likes this.
  4. Jul 2, 2024 at 8:56 PM
  5. Jul 2, 2024 at 9:19 PM
    Ice cap & super white both have the paint code 040.
  6. Jul 2, 2024 at 9:29 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    I'm finding touch up paint on Amazon #077 when I enter Ice Cap. Is that correct?
  7. Jul 2, 2024 at 9:30 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    077?
  8. Jul 2, 2024 at 11:21 PM
    scottiezilla
    scottiezilla New Member
    Not being perfect is a breath of fresh air
    Forget the scratch but remember you drive a truck
    (Bummer through)
    don’t have the app but this video pops up in my head My folks bought a rug from somewhere cross the pond
    They purposefully put in a wrong or mid-stitch in respect
    Otherwise it’s too perfect
  9. Jul 3, 2024 at 3:21 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
  10. Jul 3, 2024 at 4:20 AM
    A scratch is nothing, those can be touched up for $20. I got WORSE the first month I owned my SloRunner: Someone door dinged my rear passenger door. The ding was so bad you can see the tiny dent in the door. I'm too cheap to get a guy to repair it, but I should.
    Instead it serves as a reminder to be cautious when parking next to others.
  11. Jul 3, 2024 at 6:09 AM
    toolndie7
    toolndie7 New Member
    24 ORP
    NeverTooLate71[OP] likes this.
  12. Jul 3, 2024 at 6:53 AM
    DangitDad
    DangitDad New Member
    Ken
    2023 White 4Runner
    3"/2" Ironman lift, Method 703 wheels, K02's, Pedal Commander, more to come
    At least you didn't scratch it yourself... like me. Dangit.
  13. Jul 3, 2024 at 6:58 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    What about that stuff on the TV commercial where the man purposely scratches a new auto and squirts the shit on the auto, rubs it, and the scratches are gone. Surely they're not lying, (LOL).
  14. Jul 3, 2024 at 7:53 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    I'm not sure what color code ice cap is - looks like others are saying it's the same as super white (040).
    If that's the case, I bought a bottle of that off Amazon and it matches well. I used it to touch up rock chips on the hood every few months (before I got the bug deflector) and even used it to cover some really nasty rash on the rear bumper plastic when I took it off and rolled it on the driveway like an idiot changing the rear valance. Color matches well when properly shaken
  15. Jul 4, 2024 at 6:15 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    I had dent wizard remove a large fender dent on my 2020. It cost me $250. Insurance wanted $750 at a body shop. :hattip: Hell no!
    The sheet metal on the 4runner is paper thin just like the paint
  16. Jul 4, 2024 at 8:36 PM
    I paid about the same to have a door ding removed by a dent wizard type outfit. It’s on a black car, and the repair was essentially perfect. Good stuff.
    The 4runner skin may be thin (ish), but I’d be willing to bet it’s nowhere near as thin as the incoming 6th gen!
    mrmike7189[QUOTED] likes this.
