2.5" front 1.5" rear leveling kit question
Discussion in '5th Gen 4Runners (2010-2024)' started by emtuzas, Oct 15, 2019.
  1. Oct 15, 2019 at 9:18 AM
    emtuzas
    emtuzas [OP] New Member
    Hello all,
    I am getting mixed information and want to be sure before i do anything.
    This is for 2016 SR5 -
    I'd like to go with procomp 3" front and 2" rear leveling kit install, but it looks like this will require a differential drop, skid plate drop and also recommends a new struts for a lift that high.
    If it makes it much easier, i would be ok with Toytec 2.5" front and Daystar 1.5" rear, but I am unsure if that would still require any of the above mods (drop diff, drop skid plate, struts?)
  2. Oct 15, 2019 at 11:25 AM
    Lift is a lift doesn't matter what brand.
    Diff drop doesn't do much but its cheap as hell so I say why the hell not if you get it.
    You should get new struts regardless your stockers aren't meant to operate on the extra travel.
  3. Oct 15, 2019 at 11:41 AM
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    If you are going 3/2 you will also need upper control arms.
    If you go 2.5/1/5 you wont need upper control arms. I have heard you want 2.5 degrees caster as a minimum spec per Toyota. I was able to get 2 degrees on both sides. No issues. I come from driving sports cars and am very sensitive to changes and cannot tell a difference.
