17x8.5 -25 offset Or 17x9 -12 offset?
Discussion in 'Wheels & Tires' started by Malossi168, Nov 15, 2022.
  1. Nov 15, 2022 at 2:51 PM
    Malossi168
    Malossi168 [OP] New Member
    2018 4runner trd orp
    Im planning to get a new set of wheels for my 18 Trd Orp. Cant decide between 17x8.5 -25 or 17x9-12. I just want a slight aggressive stance. I have a dobinsons ims suspension 3 front 2 rear. i'll be running 285/70/17 for my rubber. Dont mind doing bmc and viper cut.
  2. Nov 15, 2022 at 3:39 PM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    I run -25 and its just a bit too much even with a 265/70/17 and an Eibach Pro Truck Stage 2 kit. Was able to get the camber adjusted out enough it finally stopped rubbing in reverse. Most OEM wheels are +5 to 0, so even a -12 is more than enough to pull the wheels out to the edge of the fenders.
  3. Nov 15, 2022 at 3:55 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I wish I would of went with -25.
  4. Nov 15, 2022 at 4:13 PM
    Malossi168
    So the 17x8.5 -25 will be more agressive than 17x9.-12? I just a lil bit of poke.
  5. Nov 15, 2022 at 4:14 PM
    Malossi168
    What wheel,width and offset did you went?
  6. Nov 15, 2022 at 4:31 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    I've been debating width and offsets for so long, I'm at analysis paralysis and haven't ordered a set, still stuck with my OEM TRD wheels, haha!
    I recently found this online calculator that's very helpful... "willtheyfit.com" - so you can visually see what, if any, clearance issues you'd have and how much poke each setup would provide.
    For example, I quickly plugged in the numbers you proposed and the 17x9 -12 would be 6.6mm LESS poke but 19.4mm closer to your UCA...
  7. Nov 15, 2022 at 5:30 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    17x8.5 rrw rr5v -12
  8. Nov 15, 2022 at 5:42 PM
    Malossi168
    Look good. Any front shot? Got a little poke already. I was looking at RRW r6h or 7h. But the -12 sold out already but a few -25. I like the summit wheels too. Thats where the 17x9-12 from.
  9. Nov 15, 2022 at 5:42 PM
    Malossi168
    Thank you.
  10. Nov 15, 2022 at 5:42 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Its perfectly flush
  11. Nov 15, 2022 at 5:43 PM
    Malossi168
    It looks like a little bit over fender in the picture.
  12. Nov 15, 2022 at 6:34 PM
    Sandman317
    Sandman317 New Member
    2022 AG ORP
    This is a 17x9 -25 w/ 265/70/17. Has a nice stance to it IMO but nothing obnoxious.
    RichieRich, 2Toys and Jareds Toyota like this.
  13. Nov 23, 2022 at 7:14 PM
    Jareds Toyota
    Jareds Toyota New Member
    Jared
    2019 TRD Offroad
    What wheels?
  14. Nov 25, 2022 at 6:29 PM
    Sandman317
    2022 AG ORP
    Summit Dakars
    Jareds Toyota[QUOTED] likes this.
