14-18 4Runner XB LED Headlights on Preorder
Discussion in 'Lighting' started by Headlight Revolution, Sep 12, 2019.
  1. Sep 12, 2019 at 1:17 PM
    Headlight Revolution [OP] Vendor
    Atlanta, GA
    Hey There my good friends! Just wanted to drop the Heads up for you all that the Morimoto XB LED Headlights are officially open for Preorders to all. :)
    NOTE: If you do place a Preorder, make sure to add in the Order Comments "4Runners.Com"
    PRE-ORDER STATUS:
    These have shipped and are expected in hand late October / early November 2019. If you place an order that includes these, the entire order WILL BE HELD until these arrive. THANK YOU!
    No Substitutes:
    If you don't have LED powered headlights on your Toyota 4Runner, then you're just behind the times! Thankfully the new Morimoto XB LED headlights: Look great. Are well-built. Have a virtually infinite life span. An unbeatable warranty, and out-perform the alternatives. Easily making them the best Toyota 4Runner LED headlights on the market today.
    Performance:
    We've always been blown away by the fact that the other brands don't even consider how well their headlights perform on the road at night. Most often, they're a downgrade compared to even the standard halogen setup, and that's a shame. The good news is that Morimoto's XB LED headlights produce a well defined beam pattern with a great amount of width, intensity, and a proper distribution of light.
    DOT Approved:
    Make no mistake, these Toyota 4Runner LED headlights from Morimoto will produce a much different [better] result than slapping some LED replacement bulbs into your stock housings. Their quad-projector optics meet & exceed all SAE, DOT, and FMVSS108 regulations when aimed properly...and that's easy to do with their integrated vertical/lateral adjusters.
    Plug-n-Play:
    Wiring is easy too! The XB 4Runner LED headlights are designed to work without any modifications. They will plug into the factory connectors for the stock headlights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No error codes, no flickering, hyper-flashing, or radio interference. They can easily be removed, and will not void your factory warranty.
    Sequential LED DRL:
    Game Changer! Their LED daytime running light is powered by Osram 5000K LEDs and is insanely bright, easily visible during the day. At the top of the housings, a row of amber LED's provides the turn signal function. You can set them up to run as sequential or solid signals according to your preference.
    Well-Built:
    Their UV-coated polycarbonate lens will resist the test of time, ensuring your Toyota 4Runner LED headlights will look good as new for many years to come. The PPS plastic housing is light-weight and much stronger than comparable alternatives. The die-cast aluminum heat-sinks inside the housings provide more than an adequate amount of cooling for the OEM grade Osram LED chips that produce the light. These complete headlights may be new to the market, but Morimoto's XB LED fog lights have proven themselves perfect after 5+ years out now, which is confidence inspiring.
    They Look:
    Amazing. At least in our opinion! The subtle elements incorporated in their design are more than enough to make them stand out, but they're clean enough to be considered original equipment to those who don't know any better. The piano black trim and smoked gray reflectors keep the color scheme neutral, and the quad kuria-optic projectors are as modern as it gets.
    Customizable:
    Thinking about paint-matching some OEM headlights from Toyota? Forget it man. Those things are nearly impossible to open up and then reliably re-seal. Going that route, you’ll be facing hours and hours of labor and a high probability for "hack job" status in the end. With Morimoto's 4Runner LED headlights, that job is painless! Since they're sealed with Butyl Rubber, they are much easier to open, customize/paint and then reseal!
    What's Included:
    -HEADLIGHTS: 4RUNNER XB LED (Set - L/R)
    -WIRING: Plug and Play Harness
    -LED DRIVERS: XB LED Driver Modules
    -WARRANTY: 5 Years
    NOTE: DUE TO XL SIZE / WEIGHT, THESE ARE EXCLUDED FROM FREE STANDARD SHIPPING
    Compatibility:
    -4RUNNER: 2014-2020
    -REPLACES: OEM Halogen Headlights
    -WIRING: Plug n Play
    -MEETS: DOT, SAE, FMVSS108 STANDARDS
    Tech Specs:
    -TRAFFIC PATTERN: LHD ONLY
    -INPUT: Proprietary Toyota Multi-pin
    -WEATHER RATING: IP67 Waterproof
    -LENS MATERIAL: High Impact Polycarb (UV-Resistant)
    -LIGHT SOURCE: Osram Ostar Headlamp LED
    -LED OPTICS: Kuria Quad Optics
    -INTENSITY: 2,600lm (raw; each)
    -COLOR: 5500K (Pure White)
    Check out this little teaser video from Morimoto: https://youtu.be/L-F3MGsHh9M
    Bottom line: These headlights are absolutely Badass. These bad boys are going EXTREMELY fast on Preorder. Make sure to snag a set for yourself before they are all spoken for, as they are going to be a couple months out afterwards!
    Headlight Price: These housings come in typically at $1,350 USD, but they are on Preorder for $1,150.00 + Shipping. (Typically $50-$80)
    Product Link: https://headlightrevolution.com/2014-2020-toyota-4runner-xb-led-headlights/
    Please let me know if you have any other questions for me, and I would be more than happy to help!
  2. Sep 12, 2019 at 1:30 PM
    Seems like you covered everything except the price. They do look amazing though.
  3. Sep 12, 2019 at 1:32 PM
    Atlanta, GA
    Ah yes, good catch! These housings come in typically at $1,350 USD, but they are on Preorder for $1,150.00 + Shipping. (Typically $50-$80)
    SlvrSlug[QUOTED] likes this.
  4. Sep 12, 2019 at 7:22 PM
    ForRun
    ForRun 4Runner
    2020 orp
    These are not Dot approved and please read up on the other forum. Unless you drive with fog lights on, be prepared to hit a curb or 2 in dark areas. Zero lighting to the sides up close. Dot would never approve them.
    Had them in my runner for 2 days and was glad to dump them and go back to hid. Many others felt the same.
    Even the guy they gave a free set to took them out for saftey
  5. Sep 12, 2019 at 7:43 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Oh, they look nice as heck.
    Here, at post 343 is where the 1st test mule revealed the problem. He got his free and pulled them! Post 362 is where I basically laser aligned them to perfect spec and I found the problem. you can aim lower but then distant vision is bad.
    Me and many others got stuck eating a hundred bucks + in return shipping along with fun times of pulling our bumpers and wasting time to swap light, alignments and test driving.
    Aside from unsafe the outward lighting was bit awkward with an odd cutoff line.
    Others love them and simply use the fogs. Whats wrong with that? How do you like driving and seeing some asshat blaring way to much light in your face? I don't and that's why I pulled them, fogs are meant for bad weather. read into that thread and there is a scientific post about why driving with fogs are unsafe (they draw your eyes to close distance and you don't focus on shit far away). Xenon depot agreed with that statement.
    Morimoto and Xenon depot said they had no intention of correcting tis in the production run.
    Post 463 is where Xenon depot said the 10% return rate they had with the initial sale is acceptable.
  6. Sep 12, 2019 at 7:45 PM
    Dark Knight
    Dark Knight Get off my lawn
    Also heard these SUCK.
  7. Sep 12, 2019 at 7:48 PM
    Agent_Outside
    Built 2011 T4R Limited
    From what I’ve been reading I wouldn’t touch these for half that price!
    Dark Knight likes this.
