10 ABS/VSC/Trac codes on 2002 4runner
Discussion in '3rd Gen 4Runners (1996-2002)' started by Xinoki, Sep 1, 2024.
  1. Sep 1, 2024 at 8:23 PM
    Xinoki
    Xinoki [OP] New Member
    Denson
    2002 4Runner
    2002 4runner 4WD limited. Just put rebuilt engine in and everything is running. I have 10 ABS/VSC/TRAC codes, not sure where to start. Could they all be related or some of them?
    C1266
    C1340
    C1258
    C1244
    C1233
    C1234
    C1268
    C1201
    C1223
    C1231
    Any help appreciated. Not sure where to start.
  2. Sep 2, 2024 at 7:53 PM
    Did you clear/reset the ECM and see if these all came back? I would try that first. I know with a new engine, probably everything got reset, but it's free to try.
    What is this engine out of? Which ECM did you use?
  3. Sep 5, 2024 at 8:38 AM
    Xinoki
    Denson
    2002 4Runner
    Thanks for the response. I did clear the codes. Most of the ABS codes went away, I have some 4WD related codes. the engine is from 1997 and the 4runner is 2002. I used the ECM from the 2002.
