1" Cosmetic Lift For 2022 SR5 Premium 4WD
Discussion in '5th Gen 4Runners (2010-2024)' started by Rick G., Nov 16, 2023.
  1. Nov 16, 2023 at 5:01 AM
    Rick G.
    The Texas Hill Country
    I've finally obtained a 4RUNNER. It's a pre-owned / certified '22 SR5 Premium 4WD on stock size 265/70 R17 tires. I may get different tires for it, but will stay at the same tire size, without going super radical in off road tread design.
    My primary interest is I want to lift the front end by about an inch to eliminate that characteristic forward looking lean. I will not be loading down the vehicle very frequently or towing heavy trailer weights.
    I'm just wondering which route to take on this. I don't want to harm the front drive line components or ruin the alignment or harm the handling.
    I'm thinking of one of two methods- Using those so-called Corn Fed front lift spacers, or, going with something like Bilstein 5100 series adjustable lift front shocks.
    I am not going rugged off roading with this thing. I just want the look of lifting the front about an inch for appearance purposes, while not compromising the otherwise stock features of the front end driveline / suspension.
    The vehicle is presently at 28,9XX miles on the odometer.
    Anyone been down this road? Thanks in advance.
  2. Nov 16, 2023 at 5:09 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
  3. Nov 16, 2023 at 5:15 AM
    Oakboro, N.C
    Welcome to the forum.
  4. Nov 16, 2023 at 5:23 AM
    TXKK626
    TXKK626 New Member
    Fort Wayne, IN
    2021 Venture Edition
    I went the Cornfed spacer route due to the cost savings and lack of anyplace to off-road close to home. An unexpected bonus is that that it eliminated at least 50% of the nosedive when braking — less squishy feeling coming to a stop. The braking is so improved, I wish I would have done it sooner just for that reason alone. Mine looks to be just under perfectly level, so retaining just a touch of rake. Do it. Just remember to get an alignment afterwards.
    Another thread to check out on the subject https://www.4runners.com/threads/1-inch-front-lift-only.33492/
  5. Nov 16, 2023 at 7:55 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    Did 1" Cornfed spacer only up front to my 2015 SR5P. I think this is how it should look from the factory. Once you do it you notice how much rake the 4Runner has direct from the factory.
    Adding more resources;
  6. Nov 24, 2023 at 8:47 AM
    Rick G.
    Thanks to everyone for your replies, advice and topic links. I’ll provide updates when I start taking actions.
  7. Nov 24, 2023 at 9:37 AM
    I'd go spacer too.
    Note that a spacer for 1" of lift will actually be only .5" tall.
