'04 4.7L Timing Belt and Water pump time..
Discussion in '4th Gen 4Runners (2003-2009)' started by Dolm, Feb 27, 2022.
  1. Feb 27, 2022 at 11:48 AM
    Dolm
    Dolm [OP] New Member
    I'm about to get a Gates kit (pump, timing belt, etc) and have my shop replace the belt and pump. I was wondering if there's anything else I should have my mechanic look at when he does these.. like, any "while you're in there" things to check or do?
  2. Feb 27, 2022 at 2:45 PM
    4evaRunning
    4evaRunning New Member
    My advice is to pay a little extra and get the aisin kit. Gates are junk especially the water pump. They’re use to be quality parts that gates put together but lately in the past 3-4 years , they been using cheap china stuff and piecing them together for overprice.
    I had to redo mine with aisin after 60k miles with Gates.
  3. Feb 27, 2022 at 9:27 PM
    Agreed TOYOTA or TOYOTA supplier parts only! (Aisin, Mitsuboshi, etc)
  4. Feb 28, 2022 at 4:26 AM
    Dolm
    Thanks for the heads-up. Is there anything else I should have the mechanic do while he's at it? I'm at about 215k miles.. I seem to recall a maintenance schedule someone posted a while back but I couldn't find it again.
  5. Feb 28, 2022 at 5:38 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    If youre in there the thermostat is an easy replace too. Also the accessory belt for when you put all that back together. Otherwise just put eyes on everything. Barring something egregious these engines last, you should be fine.
  6. Feb 28, 2022 at 7:30 AM
    On the third gen, I replace the belt, pump, and ALL timing pulleys\bearings. I do the tensioner every other t-belt change along with cam and crank seals.
    Last time I was in there, I replaced my leaky valve cover gaskets. Dunno if you guys have that issue on the 4th gens.
  7. Feb 28, 2022 at 7:40 AM
    iamincrediboy
    South FL
    +1 on timing belt tensioner good call. headgaskets also worth taking a look at.
  8. Feb 28, 2022 at 10:16 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Make sure to replace all the belts and hoses while you have everything apart.
  9. Mar 15, 2022 at 6:03 PM
    4-Funner
    4-Funner New Member
    2007 Limited 4.7L V8
    THIS! X1000
    The AISIN kit is all Toyota OEM parts and includes everything you'll need except for Toyota's FIPG (Toyota Seal Packing 1282B #08826-00100) which is needed for the top rad hose outlet. I wouldn't skimp here either as a lot of other premium gasket sealers don't fare so well with Toyota's pink super long life coolant.
