'03 4Runner Window Rubber Seal Missing
Discussion in '4th Gen Builds (2003-2009)' started by Drumline119, Jan 9, 2024.
  1. Jan 9, 2024 at 10:23 AM
    Drumline119
    Drumline119 [OP] New Member
    2003 4Runner SR5 v8 205k
    Yesterday my front driver window had the lower rudder seal break apart and fall off. I think it became brittle over the years. The sides and upper seal appear to still be in place. The missing lower rudder seal now causes a bunch of wind noise to fill the car when driving on the highway.
    Does anyone know how this can be replaced, and with what product? Thanks in advance! (See photos)
  2. Jan 9, 2024 at 2:34 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    From your Toyota Dealer.
    "Belt Weather Strip" for the outside, there's one for the inside and one for the outside, insides are felt coated, the outsides are rubber, different part numbers, it appears you need the outside, just make sure they sell you the correct one for the outside and for the correct door.
    That being said if one has gone bad the other 3 and the one for the lift gate are most likely needing replacing as well.
